Old 09-22-2004, 03:21 PM
Jim Mitchell Jim Mitchell is offline
I'm in the middle (not really in the middle, more like the beginning) of swapping out my four drum brakes for four disc brakes. Anyway how do I pull the axles out on the rear. I know it's a dumb question but I need a little help.
Oh, my jeep "eyeball" is a 76 Cherokee NT, dana 44 f/r, chopped top, fullcage, 6" Rusty lift, 35" BFG, BW 1305 th400, 258
stuff that is in my garage waiting to be done
12k milemarker, steel for custom bumpers, racing seats and harnesses, cb, header, intake and 4bbl, paint, lockright locker,
anyone wanting to wrench, comeon over 19362
Old 09-22-2004, 03:59 PM
J10/J20 Project J10/J20 Project is offline
Hi Jim,
Your Jeep being a 76 should have disc up front from the factory.
If your swapping axles in the rear.
You first jack up the body untill the tires just leave the ground then put some jack stands under the frame. SAFETY FIRST. Then remove the tires, rear drive shaft, brake line, shocks, and emergency brake lines. Unhook vent line. Unbolt Ubolts then unbolt the rear springs from the shackle and roll the rear out. Install in reverse.
Jack up the car from the axle and support it under the axle with jack stands.
If your wanting to pull the axle shafts then unbolt the 4 bolts on the axle flange. Take the drun off and you can find each bolt by rotating the shaft. Once you have all 4 bolts off it will should just pop out or off. You might need a little help with a mallet.
[ September 22, 2004, 10:04 PM: Message edited by: J10/J20 Project ]
Paul<br /> 78 J10/J20 (NoHurry)<br />front 44H/D, rear 60FF<br />TH400/Dana 20<br />33 gal. custom gas tank<br /> 93XJ 3.5 RE, 31\'s,<br />30 locked<br />Dana 44 lsd<br /> 69 Sunbeam Alpine GT
Old 09-22-2004, 04:38 PM
I thought 76 cherokees had standard front disc too but I have been told it was only standard on wagoneers and was an option on cherokees and J10
Old 09-22-2004, 04:41 PM
I meant axle shafts and not the axle
Old 09-22-2004, 05:02 PM
Michael's Avatar
Michael Michael is offline
Remove drum. Turn axle shaft look through hole. You will see bolt head for the backing plate there are 4 bolts per side. You will need a slide hammer. Once un bolted connect the slide hammer to the wheel studs and give it a few big yanks. And wham it is out. Same on the other side.
1994 YJ
Amc 360
TF727
Stak 3 speed
44" Pitbull Rockers on Trailworthy H1's
Rockwells
76' Wagoneer
401....new project
Tow Rig Daily Driver// 2007 6.7 CTD Dually
