Old 07-22-2021, 06:50 AM
waggygrady waggygrady is offline
v8 crank shaft
My crankshaft is toast and I'm having trouble finding a new one. The part doesn't seem to have any numbers on it for id.
AMC V8 1989.
Thanks
Old 07-22-2021, 09:51 AM
if you post a want ad in the classifieds here, I am sure someone will have one laying around. The 360 crank is pretty ubiquitous. Or if you post a want ad over at theamcforum.com I am sure they will help you out, too. There are awesome folks on that forum and they are ridiculously helpful. No way I could have finished my engine build without them.
I see you have a wanted ad for the whole engine over there already. That's good! Also, SC/397 usually has a few cores laying around. If I ever need another AMC V8, that would be my first contact. BUT he is about to retire so gettem while he's hot (he may not be taking any more builds on but I am sure he would be happy to sell some inventory off, like a crank or 360 core).
Old 07-22-2021, 10:31 AM
Crank
Thanks for the help.
My 89 V8 360 has the following number on the block 3195528ad 360
Trying to find what engine this is. I was told it was the original when I bought it but doesn't appear to be. Have to make sure I get the correct parts.
Old 07-23-2021, 06:46 PM
Cliff's Avatar
Cliff Cliff is offline
Call Kennedy American (Ohio). If he doesn't have one he knows all the AMC contacts within a few hundred miles.
Cliff Danley
1977 Cherokee S
Old 07-26-2021, 02:50 PM
a 304 crankshaft will work as well(they're the same)
~1975-1991
Another steering shaft alternative cmelo General FSJ Tech 17 04-01-2017 11:53 AM
Crank shaft thrust Raincheck General FSJ Tech 11 05-28-2011 02:57 PM
CV shaft in rear short WB Rig amc75matador Off-Road FSJ Tech 11 01-04-2009 09:01 AM
J20 Steering Box plumbed for assist and rebuilt Elliott Off-Road FSJ Tech 12 09-08-2005 11:42 AM
*EDIT* 31 spline shaft makes it STRONGER! *EDIT* dnixon Off-Road FSJ Tech 19 11-19-2004 07:26 AM
