Old 03-15-2021, 12:05 PM
mwood65's Avatar
mwood65 mwood65 is offline
Tires rubbing?
Was wondering how you guys run larger tires on your vehicles and I know many have lift kits but thats not my issue.
When I bought my 74' Cherokee it has 31x10.5 -15" tires and the rubbed the frame when turned sharp?
You guys use spacers or off set wheels?
Running 235/75-15's now
Old 03-15-2021, 01:04 PM
My truck is very different from yours but so I can't really answer exactly. But you did ask:
Originally Posted by mwood65
...You guys use spacers or off set wheels?
I got my wheels used on Craigslist for dirtcheap. $125 for 5 matching steel wheels. The backspacing on mine are terrible because they were from a Datsun mini-truck. I run spacers in the back, and have run them for a couple years, no problem. Lots of people hate spacers but I have not really had any problems with them. I found my spacers, also on craigslist, for cheap. I think I paid $25 for two, inch and a half spacers from a Tundra. Then I had to do dump 10 more bucks for 12 metric lugnuts at Costco. I now mave SAE lugnuts in the front and metric in the rear.
All that to say: Yeah, I run spacers in the back. I have a completely different wheel well than you so the sizes are not important.
Old 03-15-2021, 01:19 PM
I've read repeatedly about 10.5" tires rubbing on full lock. You could go down an inch on the width of the tires to 31x9.5 from what I've read.
--Rob--
My build thread:
My Howell TBI Install How-To:
Old 03-17-2021, 07:24 AM
There should be a stop on one of the knuckles you can adjust. The size of the tire does limit the turning angle. I would note that rubbing against the frame at full lock is not particularly harmful, just annoying.
Tires, age, and wear twmattox General FSJ Tech 4 03-14-2012 05:41 PM
Tire Pressure for 31" tires JohnIL General FSJ Tech 13 03-16-2011 08:57 AM
Well, 2 out of 3 ain't bad...Say no to bias ply tires. J10Mike General FSJ Discussion 22 05-20-2010 09:53 PM
Overload Spring ? incorrect installation / tire rubbing TimK General FSJ Tech 18 08-10-2005 12:54 PM
Used Tires and a Quadratrac BIGYELLOW78J10 General FSJ Tech 6 04-29-2001 05:16 PM
