Old 02-16-2021, 11:29 PM
jeepman42 jeepman42 is offline
Post Front wheel bearings How to GW
Changed out front wheel bearings on my '85GW.
note bearing not same #s on '85 & '90
Can not do unless you have correct tool 25072 or equiv. to remove retainers.
Have a manual.
Use wood stick or flat punch to remove races from hub. tap crosswise at 180 deg , mod pressure to remove
Use old race to seat new race. tap in as above.
Check fit of rear bearing on shaft to make sure it goes on. (Had issues w this on one side.)
Lube bearing & races w wheel bearing grease by hand or bearing packer.
Seat rear seal after rear bearing in place. Have at least one spare seal. Trust me on this. Seal should be flat & flush w back of hub. Spring not loose from seal.
(used STP as lube on seal & races.)
Place hub/disc brake on shaft,insert outer roller bearing, cover on bearing.with cup toward bearing,ie flat side out.
Insert inner retainer w short "pin " outward, tighten per inst,place retainer ring w holes(must fit on 'pin") -see inst. (not simple for me), place outer retainer, tighten 50+ ft.lbs.
Replace spring smaller dia. out, place axel gear & then
spring clip on 2nd axel slot.
Nothing is new, but it may be new to you & me! Good luck
Old 02-19-2021, 12:45 PM
Jeep Doctor
Good description; I did a pair of videos illustrating that procedure (on a J-20, but the basic design is the same):
Disassembly:
https://youtu.be/PjMAzTg5H_0
Reassembly:
https://youtu.be/jvMJBz01KYw
Old 02-19-2021, 07:23 PM
Bob Barry Thanks for the follow up -'picture is worth a thousand words'.
Def on my need to learn list!
Love my '85 GW-Linda G in more than one way since it's named after my wife of 15 yr who tolerates my Jeep Mania!!
Easy doesn't do it!!
J4000 front wheel bearings Latta brook General FSJ Tech 3 11-16-2017 08:41 PM
Front wheel stud? shakari General FSJ Tech 3 09-05-2011 04:17 PM
Gotta be wheel bearings? New question... please look again... Dirtball General FSJ Tech 35 10-10-2007 12:43 PM
Front Wheel Bearings Rat General FSJ Tech 5 09-17-2002 12:42 AM
front wheel bearings '89 GW garcia General FSJ Tech 1 09-14-2001 01:45 PM
