Go Back   International Full Size Jeep Association > Classifieds > "Look Here" for Parts, Vehicles and Vendors > Wanted
Old 01-02-2021, 02:43 AM
Waggymcgee Waggymcgee is offline
Steering column trim
Not sure how much of a shot in the dark this is but figured I would try. Does any one have the steering column trim piece that would fit an 85? It's the piece that goes around where the column goes under the dash. Thanks!
Kerry (she)
85 GW w/ HD tow pkg
Old 01-02-2021, 11:23 AM
letank's Avatar
letank letank is offline
they are a pain to remove and usually end up missing one of the screw tabs, it is a 2 part piece.
Michel
Old 01-16-2021, 11:31 PM
I got a set!
Kerry (she)
85 GW w/ HD tow pkg
Steering column swap mwood65 General FSJ Tech 5 10-06-2018 07:01 PM
Automatic Steering column/ Manual steering column compatibility posulli88 General FSJ Tech 2 02-04-2018 12:27 PM
Replace lower steering column bearing w/o removing column? posulli88 General FSJ Tech 2 02-03-2018 06:41 AM
Fuel Gauge / Steering Column Question Golden Eagle General FSJ Tech 2 03-22-2011 05:24 PM
Steering Column Compatibility Jacksons Hole General FSJ Tech 0 03-13-2011 10:16 AM
