Old 01-22-2020, 01:58 PM
MReese Wagonner's Avatar
MReese Wagonner MReese Wagonner is offline
Early vs Late V8 accessory Mounting
So I am working on my 401 for my 1983 Brougham
the 360 had a 3/8 x 6 bolt holding the alternator in, through 2 brackets and the spacer, this is the one the alt swings on at the top
the 401 has a 7/16 bolt in that space
now I thought I have read somewhere they did change that along the way somewhere
What year did that change
so far i have ordered an alt from BJs which they say should work from the '75-'77 years
am i on the correct path
I will drill out the spacer and the brackets if the alt is correct
Old 01-31-2020, 10:52 AM
You sure the difference isn't A/C vs no A/C?
Old 01-31-2020, 09:14 PM
Yep , the passenger side head early vs late around 1975 they changed from 7/16 to 3/8
There is no 12si style alternator with 7/16 so I am left to drill out the
Old 02-10-2020, 05:00 PM
will e's Avatar
will e will e is offline
Always Broke
I drilled out the alternator housing. Easy to do since it is aluminum.
You'll find that the exhaust bolts are all the larger size on the 401 heads too.
And plan on reusing your 360 oil pan. It's notched for the exhaust.
early shift knob on late column. Ristow General FSJ Tech 5 05-07-2014 10:01 PM
oil filter differences -- early 80's to late 80's rmorit01 General FSJ Tech 2 07-01-2005 12:38 AM
Grill option for late 70's wagoneer Mjr Minor General FSJ Tech 3 11-26-2003 02:21 AM
258 Intake/Exhaust Manifolds..... 76'kee General FSJ Tech 19 11-17-2003 10:54 PM
65 wag body on late Kaiser/ early AMC frame? TimK General FSJ Tech 3 07-23-2001 02:29 AM
