10-27-2017, 07:04 PM
GM standalone cruise control swap
Anybody done it yet?
I have a unit from the wreckmaster I bought for punishment, er I mean parts.
You know the one, used on GM cars/trucks 80s & 90s.
I am guessing it will be an easy swap.
Especially since I have TBI already, the column stalk is GM, etc.
Be nice to lose the stupid vacuum crap archaic setup!
10-27-2017, 10:04 PM
No vacuum??? Maybe work on a Diesel?
Got pics?
Sic friatur crustulum
10-28-2017, 11:41 AM
I'd be interested as well if the column switch was cruise only. Would be perfect for pre 1986 jeeps
10-28-2017, 12:33 PM
column switch on 86-91 is turn, headlights(hi/low), wipers, and cruise.
earlier just cruise stalks could work? I'd have to see one...
10-29-2017, 06:12 AM
The Dakota Digital unit is so easy, clean and works so well, I'll never have a vehicle without cruise control again.
Current fleet
07 JK Wife bought new...
04-20-2019, 03:40 PM
Made some progress on this recently.
Got a VSS buffer from boneyard and wired it up.
Rounded up donor stuff from my stash of junk.
Here is where it will live.
Still need to go grab female pigtail from junkyard for column cruise switch.
Stay tuned for more.
04-20-2019, 06:22 PM
You'll also may need a brake switch to cancel the cruise if you don't have one. I think it has to be a separate switch from the brake lights. I can't recall if my '84 has one but I'm pretty sure my '87XJ had two brake switches.
Good luck. I have three vehicles with non-working cruise. All my GM stuff worked forever but for some reason, Jeep and VW can't seem to keep their cruise control working.
Cruise is a must for me too. My Toyota has Radar Cruise control and it's really slick. Slows down automatically if you come up behind someone going slower than you.
My Stable:
1984 Jeep Grand Wagoneer, 5.9L, 4x4, Auto (newest project)
1997 Volkswagen Cabrio, 2.0L, Manual
2005 Kia Sportage, 2.7L, Auto
2006 Toyota Sienna, 3.3L, Auto
2018 Toyota RAV4, 2.5L, Auto
Recent projects (no longer with us)
1987 Jeep Cherokee Laredo, 4.0L, 4X4, Auto
1967 GMC 910, 283V8, 4SPD (RIP)
04-20-2019, 07:21 PM
Brake switch is in the pic. White dude w/ 2 wires.
04-22-2019, 12:32 PM
Watching.
I bought an early GM cruise stalk for my 79 and it was exactly the same as the stock "Jeep" one I removed. Since we have GM columns, I bet the wiring colors and connectors will be the same between that module and the AMC one.
https://www.thecruisecontrolstore.co...ontrol-switch/
The wiring for the switch is also the same as the Dakota Digital CC module. I am hoping all that means the GM will bolt in with minimal wiring changes.
Did that module mount up use existing holes in the fender well or did you drill new ones?
( Cherokee Build Thread)
00 Baby Cherokee
04-22-2019, 08:36 PM
Even if wiring is different on switch easily figured out.
It's just 4 wires for column switch.
I had to order a new column dealio too...mine tested bad.
Figures...but only $13 shipped for brand new one.
I drilled 3 small new holes to mount the module.
Got extra brake switch installed and stopped there.
Still need go boneyard for that cruise switch wiring connector & donor for a cable bracket.
04-23-2019, 11:40 PM
So wasted 2hrs @ local yard today.
Not a single donor for stupid connector I wanted/needed.
Going to just cut off the goofy flat connector and use something else.
04-24-2019, 06:29 PM
Come on. It just seems like 2 wasted years LOL!
My Stable:
04-24-2019, 10:08 PM
HA! no doubt...guess my phone sub-ed yrs for hrs?
Anywho wired it up, all electrical tested out as it should.
Then as usual an unexpected complication, the throttle connector for the cable is different.
Unit came from a roadmaster guess TBI is different. So I'll have to redneck engineer something to connect the cable.
Was hoping to road test it tonight
04-24-2019, 10:45 PM
For something like this, would you need TBI? Or does it just need the right pulse generator? My CC worked for about 7 minutes and might want to get something with more available parts and not running on vacuum.
1984 GW
360
Comp 260H
Harland Sharp Roller Rockers
Wiseco -21cc Forged Pistons
Performer Intake
Holley SA 670
MSD 8523
Dakota Digital custom cluster
Serehill headlamp harness
NWMP aux tank
1987 GW deceased
...but the parts live on
04-25-2019, 07:31 AM
Absolutely not, you would need a gm vss 4 out buffer like pictured.
TBI cars used them.
It takes the Jeep 8k vss signal and divides it to a 4k signal that the cruise module uses. It's a stand-alone system.
Need from donor...
Cruise module, wiring, brake pedal(lower) switch, vss buffer.
Brake switch is important it is hot until press pedal then open. Reverse of brake light switch.
All pictured above.
04-25-2019, 07:53 AM
Wiring diagram cruise module
Here is a 96 wiring diagram, pretty basic install.
04-25-2019, 08:35 AM
Nice post Tony. Very helpful.
05-05-2019, 06:56 PM
Messed around with cable/throttle hookup.
Used a little arm(modified) from LT1 roadmaster TB.
Seems since this is TBI a TBI donor would have been a better choice.
But using what I already had...
Anyway here is my solution for connection on TB.
Now I just need to fab up a bracket for cable.
Unfortunately I also need to redo my fuel lines. The cruise cable needed to be in same space as fuel supply line.
Kinda annoyed but oh well.
05-07-2019, 01:33 PM
Got the bracket figured out. Just need to redo fuel lines and should be good?
05-10-2019, 03:04 PM
Success!
Got my new fuel lines bent up & installed = road test.
100% functional just like a factory install.
So for anyone interested in losing the crap vacuum setup or do not have cruise this is a decent cheap option.
Thread Tools |
Display Modes |
