Old 08-18-2008, 10:03 PM
Matt S's Avatar
Matt S Matt S is offline
What Steering box came with what?
back in the day, I rebuilt the steering box on my 77 Cherokee... the hood was still off from doing an engine replacement, so when my rebuild failed I got to watch power steering fluid fly 50' in the air and coat the parking lot I was driving in. this event convinced me that I was not qualified to rebuild a steering box... off to the junkyard I went... they produced 3 steering boxes out of cherokees that were not as beefy as the one that was origional to my Jeep. the biggest identifier was that they only had 3 mounting holes, and mine had 4. It was a Recirculating ball unit. (I'm pretty sure when I put it back together I was short 1 ball) anyway... when the junkyard finally came up with my steering box, it was off a J-20 truck. Our Cherokee had the factory towing package, with tranny cooler, a/c, cruise, tilt, 360, th400, qt, low range, 4dr.
my question is, what option made it so we ended up with the heavy duty steering box? or was it just a fluke that the junk yard was able to produce 3 lighter units off of other cherokees?
and was that steering box the one that I read about people using to put into their CJ's when they add power steering?
Just Curious, so I ask the pros.
Old 08-18-2008, 11:24 PM
wickedwagon767's Avatar
wickedwagon767 wickedwagon767 is offline
J20 boxes were beefier than those used in the J10's,wagoneers and cherokees. Its possible a previous owner had swapped one in place of the original
'80-91 boxes had different hose fittings (o-ring vs '79 and older flared fittings),but other than that , out of the dozen or so boxes I've seen from wagoneers,cherokees and J-10 trucks ranging from 78-87 they are all physically identical.
Old 08-18-2008, 11:38 PM
onypic onypic is offline
Just an FYI, my 76 wagoneer box has a 76 on it.
Old 08-19-2008, 03:08 AM
HOOT's Avatar
HOOT HOOT is offline
I think the yard was trying to give you boxes off of something other than a FSJ. Good thing they had a J20 there. That's a better box than the rest of the FSJ's got.
I think all the boxes from FSJ's are 4 hole mounts. .
Tom Gibson
1980 J20 Utility bed truck. Factory cab and chassis truck. Many new mods for it but it will look all stock.
1985 J10 nothing special just a nice clean stock truck.
2017 Challenger. Very jealous of the Jeeps.
Old 08-19-2008, 05:14 AM
Me thinks so too Tom.
We have a couple standard size here for spares because I ain't qualified to rebuild one either. I got a kit once and then looked into the process and said eh-eh...
Old 08-19-2008, 09:27 AM
CustomWag's Avatar
CustomWag CustomWag is offline
Remember the thread by the kid who was trying to rebuild one? Showed pics of all the innards, WOW. Kid was having trouble getting it back together right & someone suggested checking the TSM. His response,"what is that?", next post was "I think I see the problem"
Rick
84 Custom GW
360/727/208/d44f/AMC20r/3:31
Manual windows/locks/seats
Old 08-19-2008, 10:22 AM
Matt S's Avatar
we were origional owners
it was shipped from factory with J-20 box... just trying to pin down why.
Old 08-19-2008, 11:47 AM
710 Burner's Avatar
Originally Posted by Matt S
..I'm pretty sure when I put it back together I was short 1 ball.
You know, its very important to keep track of those.
I have yet to see an FSJ with a 3 bolt power steering gear. Not saying they don't exist.....
Mark B. Jones
Old 08-19-2008, 02:48 PM
Matt S's Avatar
makes more sense now.
he may have been pulling steering boxes off of some other jeep... but as I recall... and I don't have the book anymore... the TSM had a teardown for both boxes. but I am hazy on that...
I just remember when I was rebuilding it... I dropped all the ball bearings, then stopped and cleaned the garage for 2 days looking for them... I was convinced I had them all, till I tried turning the wheel. all the clicks and clunks even felt like a ball was missing out of that loop. it was a neat system where every other ball was made out of a different material, dark, shiny, dark, shiny... and I should have known when I was done and had two dark ones together that there was one missing. oh well. I am still puzzled about the 3 bolt boxes, maybe they were off of CJ's or something like that. It also comes to mind that in the TSM (I am hazzy on this) that the box with 3 holes was not a Recirculating ball box. The box did have a variable gear, and part of me wonders if that was an option... but I am guessing it was standard.
glad you guys are up on your steering trivia.
Old 08-19-2008, 04:08 PM
chrisnsarah's Avatar
The FSJ box will have a 76 cast in it and use flare fittings and have 4 mounting holes. There is another common box on GM cars that uses o-rings and has a 92 cast in it with 3 mounting holes. Oddly, only 3 bolts are used to mount the FSJ box.
I wonder if the junkman pulled them off an XJ Cherokee.
'64 J200 thriftside
'67 J2000 townside custom cab
'68 Jeepster Commando
'69 Super Wagoneer
'75 J10
'79 Cherokee S WT
'75 Cherokee
'61 Aristocrat Lil Loafer
Old 08-20-2008, 06:59 AM
710 Burner's Avatar
Hmmm.....I though all Saginaw boxes were the recirculating ball type.
Mark B. Jones
