Old 10-14-2021, 08:57 AM
Brynjminjones's Avatar
1991 - Voltage drops as engine warms up
The voltage on my 1991 Grand Wagoneer has never been perfect, but I've noticed something else that I find a little strange.
When I first start it up (cold), the voltage is really strong. Even with headlights and AC on, the voltage stays well above 13.
When the engine has warmed up, the voltage will never go as high.
I'd never really paid this any attention, as I assumed it was just the high idle, but I've realised that even when driving along (after dropping off high idle) the voltage is still higher when cold.
Any ideas why this could be?
1991 Grand Wagoneer - Hunter Green. All stock. Rebuilt 360 with Melling MTA-1 cam.
1998 Cherokee (XJ) 4.0
1997 Grand Cherokee (ZJ) 4.0
1974 Ford F100 390
Old 10-14-2021, 10:09 AM
Assuming you're taking those voltage readings in the engine bay and not at the gauge...
If temp seems to be the only difference then I'm thinking loose connection or wiring somewhere.
--Rob--
My build thread:
My Howell TBI Install How-To:
Old 10-28-2021, 07:55 AM
'89_Wagon '89_Wagon is offline
I vaguely remember my OEM gauges doing the same thing.... voltage reading dropping when warmed up. Fuel(petrol?) level readings swung wildly on turns, stopping, and hills.
Are the headlights dimmer when warm?
A side note, I dropped in an aftermarket gauge cluster from digital dakota and the voltage reading was the same cold or hot. Nothing else changed. Not suggesting to buy it just to test voltage.... it's just nice being able to trust the sensor readings on the dash.
'89 Grand Wagoneer
AW4 Swap
Old 11-01-2021, 09:26 AM
Suggest you connect a reliable multimeter to the battery and follow it while you drive. Clip on and bring wires into the cabin and have your helper follow how the voltage changes.
The battery voltage is controlled by the voltage regulator in the alternator. The sense wire of the alternator detects the battery voltage and changes the output current to bring the voltage to its set point, something like 13.5-14 volts. This is the sum of the chemical potential of the battery (lead-acid is 12.6 volts) plus the product of the charge current and the internal resistance of the battery (V=IR).
Any feedback system (like this) has finite gain, which means the operating point will only approach the set point, not reach it. However, it should keep the voltage close all the time, as long as everything functions like it should.
Old 11-08-2021, 10:08 AM
jpcoutts's Avatar
jpcoutts jpcoutts is offline
I have noticed similar changes when I start one of mine and I came to the conclusion that starting the engine was a drain on the battery that required a lot of juice to re-charge and after the battery is charged back up the level drops back down. It may seem too simple but belts also impact this condition, make sure they are tight and in good condition.
Jim C
'67 J3000 Dually
'86 J20
'79 CJ5(in pieces)
Has anyone actually seen a 1991 engine? austinaubinoe General FSJ Discussion 16 08-04-2012 12:53 PM
Intermittent poor charging and voltage drops lars667 General FSJ Tech 25 02-12-2012 03:29 PM
Engine noise, 4.0 swap???? Mex in the city General FSJ Tech 5 11-24-2008 04:00 PM
Calling out Holley tbi guru's need help please Michael Fuel Injection 26 02-04-2006 01:28 PM
Rather long post on Alternator Theory...some background Joe Guilbeau General FSJ Tech 12 06-08-2003 06:53 AM
