View Poll Results: What kind of seats would you use in a "non-restoration" waggy?
Boneyard Stock 7 22.58%
Refoamed, Clean Covered 7 22.58%
Retrofit Leather from Cherokee or the like 17 54.84%
Voters: 31. You may not vote on this poll
Old 12-23-2008, 11:29 PM
spyderkeeper's Avatar
spyderkeeper spyderkeeper is offline
Seat Options
So I'm getting a little tired of vacuuming foam out from under my seats, and I'm pretty sure in a year I won't have any seats left. The question is whether to go:
1) Boneyard Wagoneer seats (cheap)
2) Take my seats to an upholster to have refoamed (can you do this???)
3) Retro fit some new cherokee leather seats like these (will height be a big problem even if they're powered?)
Marvin -- '87 Grand WAGONEER, Big Lift, Big Tire
Bob -- '89 GW, No lift, No tires
There's a reason some suspension bolts have MF on them.
Old 12-24-2008, 12:13 AM
Dmntxn77's Avatar
Dmntxn77 Dmntxn77 is offline
Hey watch this...
If I were to swap in some seats that were not for wheelin, I would only look at two options...
If going for pure comfort, I would get a nice leather set from a ZJ or WJ... Both of which have VERY comfortable seats.
Or, if I were going for function and security, I would go with some leather GM seats with the integrated seat belts. They are also comfortable, but dont really compare to the Jeep seats.
There is a write-up somewhere on here from a guy who installed Ford Explorer seats in his FSJ. They look nice, but ummm no thanks... If youve ever ridden in a Ford, you will know why....
If you already have the brackets for buckets you can just about adapt any seat to them. Yea you can have them rebuilt any good upholstery shop should be able to do this. Over the years there have been a lot of threads on here about seats search them out and see what others have done. I picked up a set of seats from a Mountainair last year for Crom hopefully they will get instlled this year along with the drivetrain update
Old 12-24-2008, 01:54 PM
mattmopar440's Avatar
OHHHH SHINY
87' Grand Wagoneer
80' J10 4BT/AX-15/208
74' J10 Go Grabber Green Sold
Inferior Chevy
847JeffL's Avatar
847JeffL 847JeffL is offline
I'm going to have my bench seat reupholsted early next year, an old man up the street has a shop and has been in the businees for something like 50+ years. I drove the truck up there and he quoted me around $135 to fix the springs and add foam. I trying to decide if I want him to put on new vinyl or just reuse the stock vinyl, his price didn't include new.
1983 J-10 360, 727, NP208, longbed, TFI upgrade, K&N filter, Flowmaster delta 50, Edelbrock Intake(3731) and Carb(1400), Summit 8600 cam, 4" Hellcreek Suspension, 3.73 gears, Treadwright 33x12.50r15 D/Mud-S, Minty's Model 29 15x10 wheels.
Old 12-24-2008, 04:21 PM
SirPaul64's Avatar
SirPaul64 SirPaul64 is offline
in the spring im hoping to find some nice leather seats for my j20 somewhere. I was thinking some Grand Cherokee seats as well those were my fav seats ever i think.
1947 Willys Pickup
2001 Jeep Wrangler
2006 Jeep Commander
1987 Jeep Grand Wagoneer
Old 12-24-2008, 06:19 PM
cu4whln's Avatar
cu4whln cu4whln is offline
I stuggled a bit with this issue - I find the stock seats very uncomfortable and not good at holding me in position well off road.
I found it very hard to find a seat that didn't sit too high. Also, the tunnel is very wide - and it was hard to get the seat inboard enough to make the armrest comfortable/usable.
I wonder if the power tracks would add too much height? Check it out before buying any seats. I ended up using some TJ seats.
I had to custom make some mounting brackets- after cutting the TJ track down by 3 inches.
Good Luck ! Post pics when done !
1977 "401" 'Da Chief
1979 Chero: "Madness" [Sold]
2001 XJ : Driver - 2016 JK 2 door
Round 2- LT Swap: 'Da Chief:
"Madness" build here:
Old 12-24-2008, 07:20 PM
Eugene 1's Avatar
Eugene 1 Eugene 1 is offline
Exploder seats work pretty good, not many mods needed for the manual seats.
JEEP
2005 Ram 1500 HemI
Old 12-24-2008, 08:48 PM
frank_c frank_c is offline
i have Bestops on GW power seat bases in my J20 and they are comfortable. much better than sliding around on the bench seat that sagged in the center.
83 Waggy
87 J20
99 TJ
05 Crossfire SRT-6
Old 12-24-2008, 09:16 PM
gotmike's Avatar
gotmike gotmike is offline
these came out of a toyota of some sort i think... garage sale special... but they're really comfortable...
J.E.E.P
Just Everyone Elses Parts!
'77 Cherokee Chief
w/ '92 12v cummins,
NV4500
NP 205
e]
Dana 60 Front axle
Dana 70-HD Rear axle
Build thread: http://www.ifsja.org/forums/vb/showthread.php?t=90702
trailer build thread: http://www.ifsja.org/forums/vb/showthread.php?p=1314880&posted=1#post1314880
Old 12-25-2008, 12:14 PM
YellowJeep's Avatar
YellowJeep YellowJeep is offline
The WJ seats are going to sit pretty high and they are pretty wide too. The hump in the floor is a major PITA. Use the factory brackets and adapt a seat on top of it...preferably with the stock seat tracks since they are very low profile.
XJ and YJ seats would probably be a really good choice. YJ seats are narrow and low.
Chad-
88 Wrangler - TBI350 SM465 Ford 8.8
79 Cherokee Golden Eagle - AKA "The Screamin Eagle" 5.3 Runs and Drives. TH400 and Q-Trac!
77 Pontiac CanAm - 6.0LSx/4l80e swap
2010 - Ford Flex Limited AKA the wifes wagon
Carbs suck!
Old 12-31-2008, 11:24 AM
crazydog's Avatar
crazydog crazydog is offline
I have Corbeau Moabs. They bolted right to the factory sliders. No drilling or anything.
1967 J3500 - Making plans
Old 12-31-2008, 05:22 PM
El Jefe's Avatar
El Jefe El Jefe is offline
I got seats out of a 98 ford contour. havent got them in the Cherokee yet, but they'll fit nicely size wise.
Alex
76 Cherokee Chief
350/th400/d20
d44/14b
4" lift, 35 inch retreads
Old 01-03-2009, 12:20 AM
1977cherokeechief's Avatar
1977cherokeechief 1977cherokeechief is offline
i have thought about yanking the seats out of my 95 f*rd probe... they are VERY comfortable.
nate
the new fixer upper
1977 cherokee chief
360, th400, QT
33" tires
edelbrock 600cfm
82 mustang 5.0 5 speed. ford racing intake, edelbrock, offbrand long tubes, and glass packs.
Originally Posted by jamsni
Just explain that you are trying to do your part to stimulate the economy. Buying it is just the right thing to do.
Old 01-03-2009, 01:28 AM
ThisGuyUKnow's Avatar
I might try a Hijack here..... are there any other vehicles (non jeep or jeep) that have bases that will match up to our trucks..... My power bases are screwy in my GW and I don't necessarily want to look at whole new seat set up mainly because my interior is the maroon and I do not think that Grey seats would look so good. That color may be slightly challenging to match.... end hijack
Old 01-03-2009, 06:52 AM
cu4whln's Avatar
Take a close look at the pass side seat track - notice how the tunnel is WIDE. This drives most of the problems with other seat tracs. The seat is inboard of the tunnel quite a bit. Driver side is not really an issue-so check the pass side first !
Here is what I did - I used manual, non tip-n-slide driver seat tracks from a TJ. Had to cut them down over 3" to get the height about right. Welded some cross braces. Then I made tabs to pick up the mounting bolts. Not easy. Had to re-drill the seat pan inboard a bit too. pic of the track and seat . .
Here is a copy of a post I did some time ago about my seat swap in another thread:
I am putting TJ seats in mine.. [2001]
The pass side is the problem.. dam wide tunnel !
So, I am using the TJ tracs, but cut down 3"... this gets you at the stock ride height for the seating position. Make sure to maintain the seat cusion angle when doing this. Also, a "Tip-N-Slide" unit would not work well due to the pivot mechanisim is in the area that needs to be cut off.
So, I am using manual driver tracs on BOTH sides..... the seat backs tip forward, and the pass seat has a nice pull tab on the front leading edge of the seat back. This lets you pull the seat foward.. there is a button on the lower seat backs as well - if you are in the back seat.
Now, the tracs are offset.... kinda like our FSJs.. but the pass side should really be inboard a bit.... if not, the armrest is too close to the seat and uncomfortable.
So out comes the hammer... I flattened the floor at the front of the tunnel area to let the trac sit in farther. The mounting holes do not line up. I will be welding a flat pc on the bottom of the trac to reach the holes.
Driver side is really no problem. Will have to adapt the mouting holes to the TJ track.
Now, the pass side has a cable that used to "trip" the Tip-N-Slide TJ trac. I think I can make a bracket that will pull the manual trac to the release position. The cable is tied to the seat back.. when it tips foward, it pulls the cable.
So what you ask ? Well, if I can get that to release the trac, I have a seat trac that will release when I tip the pass seat foward to get in the back.. How cool is that ! I am in mid project right now.. but will share when it's all done....
Old 01-03-2009, 06:02 PM
duncanstives's Avatar
duncanstives duncanstives is offline
A buddy of mine grabbed some leather power seats from a totalled 02 volvo for a bronco he has... He has not installed them but I got all the power functions to work without any trouble and since they are from a car they don't sit that high. Adapting them does not look hard and they are super comforable.. Not bad for $150.
They are kinda wide though... Not sure how they would work in an FSJ.
Old 01-03-2009, 07:41 PM
amc75matador's Avatar
amc75matador amc75matador is offline
I'm a bench seat guy. Nothing like pulling the missus close and putting my arm around her on a long trip. I only offroad on my baby Jeep and that has stock buckets
Sleep, Eat, Jeep, Repeat...
"I need Another Jeep!"
"The streets will flood with the blood of the non-believers!"
"Of all the things I've lost, I miss my mind the most!"
"Nothing makes a person more productive than the last minute"
Old 01-03-2009, 07:53 PM
mudhunter241's Avatar
mudhunter241 mudhunter241 is offline
I want to get some seats out of a 98 chevy 3500, my grandpas got them and they are awesome. Power leather captain seats for my J 10
91 XJ 4.0/AX15/NP231 4.5 Rustys
CUSTOM BUMPERS ROOF RACK and ROCKERS
74 J 10 Mean Green Monster
04 RANGER 4.0 V6 DAILY DRIVER
Old 01-03-2009, 11:03 PM
suzq044's Avatar
suzq044 suzq044 is offline
I was thinking about taking the Patriot's front seats, and recovering them without the headrest posts. Low-back seat but with some good support too. Plus, I find the Patriot's headrests particularly uncomfortable anyways.
Max²: 1964 Jeep Panel Wagoneer
Planning Stages
2018 Wagoneer Rendering if you're interested.
