02-05-2010, 03:58 PM
Lifter / Cam replacement
Got a bad lifter tick on the pass side of my 360. Is it ok to change just the lifter or will that be a bad idea because of the the cam wearing on the new lifter? I have heard that if you change just a lifter you could spin a bearing from the cam wearing onto the new lifter.
So yea or naa? I really don't have the cash right now to do a cam & lifters so if its possible to get by with just the bad lifter that would be great.
02-05-2010, 03:59 PM
Are you sure the tick is not a valve?
If it is a lifter, it is better to replace all lifters as a set.
02-05-2010, 04:04 PM
Fairly sure its a lifter, pulling the valve cover tonight, what should I look for if its a valve? Is it something that would be obvious?
02-05-2010, 04:15 PM
Look for a loose or sloppy rocker.
Scott R.
'86 Grand Wagoneer Super Chief 360 / TBI / WT conversion / 35x12.5x16 BFG Mud-Terrains ( Project Link)
02-05-2010, 04:58 PM
Aren't broken rocker arm bridges fairly common on AMC V8s?
New lifter on an old cam is ok. Never use a used lifter on a new cam, or mix up used lifters from their positions on a used cam.
I guess a new set would be better, but I don't understand the logic of it, except that if one lifter is worn out, the others are likely close behind.
If you were really short on money, you could try taking the lifter apart and cleaning it in carb cleaner, and putting it back. Improving your oil pressure might help too.
02-05-2010, 05:23 PM
Auto Trannie God
i love a flat cam in the morning
02-05-2010, 06:23 PM
if you decide you need stock cam. i have a brand new cam and lifter set that i would give you a great deal on.
02-05-2010, 08:03 PM
I had a tick after my engine sat for a few months without being run. I tried some Seafoam through the carb and in the oil. It fixed the tick. It is cheap and it might keep you from having to tear it apart.
1967 J3500 - Making plans
02-05-2010, 08:38 PM
Tried the seafoam already it didn't stop it. Going pull the valve cover now.
02-06-2010, 11:38 AM
Isn't that "I love the smell of a flat cam in the morning"?...haha
83 J-10 Jeep "Oscar"
360/727/229
02-15-2010, 11:20 AM
After looking at it I had a bent rocker bridge, ordering 2 new rocker arms w/bridge & saddles. Will see if that takes care of it or if a lifter is still ticking. I am thinking it still is going to need a lifter but my fingers are crossed.
02-15-2010, 08:44 PM
Just make sure the lifter is not pumped up with oil or it might bend again.
It should be slightly springy when you push down on the push rod by hand. With about a 1/16 movment.
If it feels like a rock it is pumped up. Only way I know to fix that is to remove the lifter and tare it down and drain it.
Or maybe time will drain it if you tighen the rocker and turn the engine over by hand untill that valve opens some and wait a few days??
All I know it that when that valve is all the way closed with the rockers on, you should be able to spin the push rod with your fingers.
Larry
88GW "Mississippi" 401,Edelbrock heads,and stuff,
4" Skyjacker, BFG AT's,OBA,Air Horn.
'89GW "Mutt" wood for now, 360, 1405, Edelbrock cam,
4"Rusty's,3"body,33"BFG. Detroit Truetrack Warn Hubs
The Metal Workshop
http://www.themetalworkshop.com/index.html
01-12-2022, 07:25 PM
Removing Lifter w/heads on?
I have a similar tick. Bought an 87 GW that had sat for 10 years - flushed everything (a few times), tried MMO, trans fluid, etc.. Ticking has gone way down but now I get occasional exhaust side popping on acceleration. Oil pressure is great so I don't think the cam is gone. IF it's not a bent or broken rocker bridge can you pull the lifters with one of those probe tools? I heard that on some motors you HAVE TO pull the heads.
"Simpson you boob, you've destroyed us all!"
'69 J2000 Gladiator (Grover)
Buick 350, F.A.S.T. 4bbl EFI, TA Stage 1 manifold, ported intakes, roller rockers, Voodoo cam, full length headers, Early Bronco COIL SPRING FRONT SUSPENSION, 700R4 trans, D20 twin stick, hydroboost, front discs, A/C
'87 GW (Lucille)
Slowly bringing her back to life
Mine's a Hybrid - It burns gas AND rubber!
01-13-2022, 09:52 AM
You replied to a 12yr old thread, but pop the valve cover on the suspected side, check for looseness of valvetrain, verify torque specs on the loose one, take intake off to get to bad lifter and use a magnet or your fingers to get it out.
01-13-2022, 12:38 PM
Thanks Rob! That helps to know the order to check. Cheers
'87 GW (Lucille)
01-13-2022, 01:16 PM
I'd recommend starting a new thread when something is so old, otherwise everyone has to slog thru all the old posts to get to yours.
My resto thread (see my sig) has some pics somewhere of exactly what I found on mine (bad lifter), sounds like yours could be similar. I did it the cheap and easy way, but cam may still be bad, and if so I'm sure it'll eventually let me know, but for now it runs pretty good.
02-08-2022, 12:27 PM
MysticRob nailed it. Concur with all he said.
If you do have to replace a lifter, you DO have to pull the intake manifold but not the heads. I just replaced on this weekend. If you do replace a lifter(s), you should do a break in (20 mins at 2000RPM).
( Cherokee Build Thread)
00 Baby Cherokee
02-10-2022, 11:36 PM
last time I replaced a bad lifter, I did all of them... and never bothered to do a break in... the engine is still running after 100kmiles.
Michel
02-16-2022, 08:09 AM
Regarding Hyd' roller lifters, Im getting mixed information on whether the Dodge lifters work, other OEM lifters fit or if you have to use the $500 set for an AMC. Any information? It hurts me to think that I can get Dodge/Ford/Chevy rollers for <$200 but AMC sets are $480
02-23-2022, 09:31 PM
Not sure about roller lifters, but reg hydraulic lifters less than $5 ea. from several sources for jeep.
I don't know if rollers have that much advantage??
Easy doesn't do it!!
Thread Tools |
Display Modes |
