Old 09-26-2021, 04:39 PM
timwiller's Avatar
timwiller timwiller is offline
front drum brake return springs
bottom line...are both upper return springs each the same size? i found a spring kit that that has them equal in size and they don't match whats on now. shorter , longer, weaker, stronger? my TSM gives no info on differences.
are primary spring, secondary spring , stronger or weaker ?..or does it matter? i should know this but i haven't worked on them in a decade.
all insight welcome.
much obliged folks..
1966 J-3600 Gladiator, 304 AMC, T-18/D-20 twin stick, D44/D53, custom mandrel bent magniflow exhaust
Old 09-27-2021, 09:00 AM
The two top return springs are the same. I'd suggest you throw away all the old springs and use new. Spring kits are cheap for the Bendix brakes.
https://www.rockauto.com/en/catalog/jeep,1966,j-3600,5.3l+327cid+v8,1493241,brake+&+wheel+hub,drum +brake+hardware+kit,1752
Look them up in the parts book. https://oljeep.com/edge_parts_man.html 62-73 J-series, group 8.008-1.
Old 09-27-2021, 10:25 AM
timwiller's Avatar
springs
thanks man! the old ones in place are weaker in front than the back. after 20 years i still find odds and ends on the beast. no telling what POs have been up to.
OT brake drum stuck Zorm General FSJ Tech 4 10-25-2011 03:20 AM
Anyone moved their front axle forward by reversing springs? Grantshire Off-Road FSJ Tech 43 04-25-2010 06:44 PM
Different Springs Up Front DevEmp General FSJ Tech 2 05-16-2009 02:03 PM
Parking brake doesn't grab, I hate drum brakes DanHS General FSJ Tech 20 10-20-2007 08:32 PM
front springs for GW/j-truck - quick help, please! Proj76J10 General FSJ Tech 3 06-23-2006 07:35 AM
