Go Back   International Full Size Jeep Association > Classifieds > "Look Here" for Parts, Vehicles and Vendors > Wanted
Old 09-25-2021, 09:43 AM
Tigger4X's Avatar
Tigger4X Tigger4X is offline
Arrow Wiring Harness / Connectors mainly - '79 J20 longbed
ISO - Wiring Harness Connectors The DSPO removed the fuse block and entire wiring harness replacing it with red & black wires from grill to tailgate. I think it's time to rewire the whole thing. I'm looking for all of the connectors to install into the new harness.
EDIT : I have a 21 circuit wiring harness that I will use with the connectors.
Please let me know what you have, pics would be great, and how much you're asking for it. My shipping info is : Springfield, OR 97475 TIA
Originally Posted by will e
Old 09-25-2021, 11:38 AM
levelhead's Avatar
levelhead levelhead is offline
pm sent
1988 GW (2)
1980 Cherokee Laredo
1979 Wagoneer
1976 J10 401
1977 Wagoneer 401
1977 J10 4 speed
1969 J3000 (2)
1955 CJ3B
1964 Wagoneer
Old 09-25-2021, 12:38 PM
Tripwire's Avatar
Tripwire Tripwire is offline
you know those generic painless wiring kits are pretty nice....just a thought
Abort? Retry? Ignore? >
Old 09-25-2021, 03:06 PM
Tigger4X's Avatar
Ive had a 21 circuit kit from BJs sitting on the shelf unopened for my '74 J10 that I can use for this, but I was thinking it would be nice to to install the factory connectors with it.
Old 09-25-2021, 03:15 PM
Tripwire's Avatar
you can buy the factory connectors all day long from web sites, you should concider upgrading both ends to weatherpac connectors... you WILL want to invest in the special crimping tool though........
Old 09-26-2021, 09:40 AM
Tigger4X's Avatar
Say whaaa? PM SENT!
Old 09-27-2021, 12:48 PM
Runyouover86GW Runyouover86GW is offline
Originally Posted by Tigger4X
Say whaaa? PM SENT!
I definitely agree with Tripwire. Most all of my builds for my customers, I will upgrade to Weather-Pack connectors and a good GXL wire. This is especially the case for anything that can be exposed to the elements or chemicals at all. And I like them a lot more, because they are much more secure and stay connected better than the older style connectors. Obviously you can't do this for specialized connectors like for light sockets and things like that, but anything else, it is a good idea.
Old 09-28-2021, 10:20 AM
Tigger4X's Avatar
I'm still trying to adapt to the terminology, but I believe the term Weatherpac are the connectors with the heat shrink on them. I have used those before, but that is not what mean by Connectors. I just installed a new turn indicator hub in the steering column and at the end of the wiring is a wide, flat plastic connector. Also at/near the base of the column are a couple of places where portions of the wiring harness attach with molded plastic Connectors. Those are what I am looking for. Tripwire PM'd me a link to a source for some of them. I will use the "weatherpac" type Connectors where the new wiring harness runs to places like the new LED taillights and markers I bought from BJs
Old 09-28-2021, 11:12 AM
Hey Keith, I have a harness I pulled out of a 78 Cherk a few years back and have been pilfering parts/wires from for a while. it's a mess and not really worth paying to ship but if you have specific connectors you need, I'll cut them out and mail them if you want. I also have the fuse block and you can have that, too, if you want it.
Old 10-13-2021, 12:29 AM
Tigger4X's Avatar
I don't know what all is needed behind the dash, but the connectors along the column and its base would be really helpful. The fuse block would help with the gaping hole in the firewall I can try to get with DarkMonohue and see what all else might be good to see if you still have. I really appreciate the help Marc
Old 10-13-2021, 09:19 AM
If you have any issues finding the connectors you might need after everyone else has helped you out here that has offered their help, just let me know the component the connector plugs into and I am pretty positive I can get most all of the ones you need.
Old 10-14-2021, 03:38 AM
Tigger4X's Avatar
Thanks Runyouover I'll have to make my list and get the party started. And I def like the idea of having anything exterior sealed up nice!
Help, wiring harness replacement key General FSJ Tech 25 09-01-2015 05:28 AM
what wiring harness fits? supercopjason General FSJ Tech 2 08-14-2006 09:10 AM
87 GW Trailer Wiring Harness bawoodvine General FSJ Tech 9 08-11-2006 02:03 PM
Wiring tech - dashboard harness - Crackpipe build Sitting Bull General FSJ Tech 7 05-18-2006 07:55 PM
Wiring harness questions. Clem General FSJ Tech 3 02-14-2005 12:46 PM
