Old 09-24-2021, 07:20 AM
waggygrady waggygrady is offline
Oil Pressure Gauge aftermarket?
Anyone recommend an aftermarket oil pressure gauge for a 89 GW 360?
Thanks
Old 09-24-2021, 07:41 AM
Autometer is the best.
Old 09-24-2021, 03:17 PM
drcom's Avatar
drcom drcom is offline
Autometer seems to be the one that works the most.
1970 Wagoneer Custom (9/1969)
Original Arizona Jeep
Buick 350/TH400/Dana20
Early model with razor grill
Spring Green exterior (original)
Custom series interior
Old 09-24-2021, 05:10 PM
inkedmonkey inkedmonkey is offline
I've been really happy with the $50 set of 3 from Speedway. Comes with temp, oil and volts. Plus the bracket. I have a set in the Wagoneer and in my 54 Buick.
https://www.speedwaymotors.com/Speed...el,396421.html
Old 09-25-2021, 12:30 PM
oil pressure
Thanks for all the tips
Old 09-26-2021, 09:03 AM
backroadin''s Avatar
Get an electric one - it's sooooo much easier to hook up and there's no oil line to plumb into the cab with the chance of it leaking or worse, coming apart and blowing hot oil all over you and your interior. It's rare, but it does happen. There's plenty of options out there, autometer, autogage, vdo, they all have inexpensive ones. I like the full sweep ones if the range is 0-100psi, and the 1/4 sweep are ok if it only goes to 80psi. Otherwise, the needle isn't going to move much with our psi ranges.
Old 09-27-2021, 11:36 AM
wincher's Avatar
wincher wincher is offline
the most recommend autometer and i have luck to get a new one in something than your craiglist here in germany. Have to complete it with a copper line from summit and i am happy with it.
78 chief 360amc
02 wj 4.7HO Overland
Old 09-27-2021, 11:45 AM
Why? What's wrong with the factory one?
Old 09-27-2021, 08:04 PM
It only reads low....................
Old 10-05-2021, 07:58 AM
Ditto on the Auto Meter. I installed a set in my rig years ago and never looked back. I have had no issues with them. The best part is that they actually read correctly. "The factory gauges seemed to be for novelty purposes only" (quoted from another member, cannot remember who)
Upgrades
2. Cs-144 Alt 10/1/11
All completed long ago (cannot remember when)
1. TBI
2. New fuel tank
3. AW-4 Transmission
4. Aluminum condensor
5. Custom Gauge Panel
Fuel Gauge / Steering Column Question Golden Eagle General FSJ Tech 2 03-22-2011 05:24 PM
upgrade to oil pressure gauge? Ulazy2 General FSJ Discussion 4 02-16-2011 01:02 PM
J10 fuel and oil pressure gauge not working bm873 General FSJ Tech 0 07-07-2007 12:08 PM
oil pressure gauge? shadowjeep General FSJ Tech 5 06-21-2006 11:45 AM
Wiring my aftermarket gauges- plugged into stock gauge cluster plug! Sycho15 General FSJ Tech 8 05-30-2005 08:15 AM
