Old 09-19-2021, 11:42 AM
mjs408 mjs408 is offline
Narrow track offset differences
My original set of axles is from a unknown year wagoneer w disks, I recently acquired a second set of narrow track axles (drums)as part of a parts package and I pulled the shafts and notice that my shaft lengths are different between the two axles when did this change.
79 J-20 Snow Boss 360 AMC
Old 09-20-2021, 04:10 PM
Front or rear? In 1980 the front went to driver drop and rear went to AMC 20 so that might be a difference.
Old 09-21-2021, 03:20 PM
Rear, one is a 74 rear, the other is a 79 rear
Ones has shaft lengths of 21.375+27.875=
49.25
the other is 19+30.375 =
49.375
Both housing are the same bearing retainer flange to flange or real close to it +/- .125
Old 09-21-2021, 05:58 PM
goldhammer's Avatar
Sounds like you have a quadratrac and a part time transfer case rears. The q-tracs were offset, more than the part time axles.
Both should be 44's, so the flanges and outer stuff should be the same, they just moved the diff housing
Art
ASE Master Collision Tech
Old 09-22-2021, 09:03 AM
A 6-lug Dana 44 centered rear axle is both scarce and sought after. A drum brake Dana 44 front axle can only be '74-76; front disk brakes became standard in 1977. These Jeeps all had rear drums.
I think you are measuring differently from how Jeep measures. The right axle from a '74-79 manual transmission Jeep (part time) is 25.24" OAL. The Quadratrac axl (full time) is 22.78" OAL. (I presume it's OAL, not shaft length)
Old 09-22-2021, 09:58 AM
goldhammer's Avatar
He said both were rears, so if a disc setup on one, it was converted somewhere along the line.
Art
Old 09-22-2021, 06:47 PM
I should have added I was not measuring overall shaft length I was measuring from the back side of the bearing to the end of the shaft where it engages with the diff.
I was doing it by myself and that was the easiest way to get it done to compare lengths/difference.
Old 09-22-2021, 07:26 PM
When I said drums I meant front, should of been more clear.
Old 09-23-2021, 01:45 PM
Well I cleared a spot on the healing bench and got my square out and did some measuring. I definitely have a centered d44 from a manual fsj.
narrow track street truck? Austin 4x4 Street & Performance 7 02-23-2013 08:26 PM
difference between wide track and narrow track. lodmccloud General FSJ Tech 11 04-28-2010 01:25 PM
Narrow track 5 lug vs 6 lug xtremos General FSJ Tech 2 04-10-2009 09:09 AM
I need offset axle help jimmy1000000 General FSJ Tech 0 02-24-2008 01:46 PM
need reverse offset wheels/deep dish to fix narrow axle appearance icuhatn99 General FSJ Tech 3 03-26-2007 09:50 AM
