Old 09-03-2021, 01:12 PM
Pillow Pillow is offline
258ci I6 single Carb rebuild kit?
Anyone have a good source and recommendation for a single barrel carburetor rebuild kit?
This is for a 1973 J4000 with the 258 cu in I6.
Sadly there just does there is many parts out there for this amazingly common engine... Perhaps everyone LS swapped the I6s
Thank you!
1983 Cherokee Pioneer - in progress LS 5.3 w LS9 cam, NP208, & SM465
1968 J2000 Gladiator truck (organ donor for Cherokee & J2000)
1973 J4000 truck - potential Gambler 500 or farm beast.
Old 09-03-2021, 01:30 PM
Thank you!
Dunno, I went right to it.
https://www.rockauto.com/en/catalog/jeep,1973,j-4500,4.2l+258cid+l6,1438034,fuel+&+air,carburetor+ repair+kit,5964
You understand that the J4000 label only gives the wheelbase, not the GVWR? A J4500 is the 5000# GVWR version which is most likely if you have a 258. Do you have the TSM? Recommended.
Old 09-03-2021, 01:41 PM
Thank you, I see it on RockAuto now.
Is the Standard Motors kit pretty good and complete?
Old 09-03-2021, 02:52 PM
Yes, Standard is fine. Possible there are better - this gets a lot of discussion on the CJ site: https://www.bing.com/search?q=site%3...carburetor+kit The CJs use the YF both with the AMC 6s and the older Willys 4s. I don't have an opinion, having never rebuilt a YF.
Old 09-13-2021, 01:31 PM
mwood65's Avatar
mwood65 mwood65 is offline
I bought mine from Mikes carburetor shop.
If you call you most likely will talk to him or his daughter and believe me she was impressive for a lady (sorry for being sexist) but that girl knows EVERYTHING about carbs,
Amazing customer service and easy to get advice or help from them.
They carry a bunch of old stuff too.
https://www.carburetor-parts.com/
Old 09-13-2021, 01:33 PM
drcom's Avatar
drcom drcom is offline
I also had great luck with Mike's Carbs...
1970 Wagoneer Custom (9/1969)
Original Arizona Jeep
Buick 350/TH400/Dana20
Early model with razor grill
Spring Green exterior (original)
Custom series interior
Carb rebuild kit (numbers don't match) 1jeep General FSJ Tech 11 02-19-2011 03:55 PM
AMC 360 running rough after carb rebuild centexjeeper General FSJ Tech 6 02-17-2011 10:18 AM
Carb rebuild - can the common man do it? RTFM General FSJ Tech 12 05-26-2010 01:18 PM
carb rebuild jeepsnfish General FSJ Tech 5 03-14-2009 09:35 PM
fuel issues after carb rebuild TLF General FSJ Tech 16 10-03-2005 03:24 PM
