  #361
Old 09-11-2021, 07:02 AM
wincher's Avatar
wincher wincher is offline
Rear Fog light
For germany licence the preowner had added a rear fog light
it is a separate swich for it , and a relais.
12 V out from the A/C connector
But now i have discovered a failure.
Rear fog light functions only with the interieur light on!
have to turn the light switch for interieur light for it.
this is probably a fairlure for my T
78 chief 360amc
02 wj 4.7HO Overland
Old 09-11-2021, 08:50 AM
Hahahahaha!! That is kinda annoying! Probably just used a power wire (either for the switched side or the power side) that comes off the interior light circuit. Should be an easy fix.
Old 09-11-2021, 01:58 PM
wincher's Avatar
yes, but i hope had the tuev meeting this wednesday.
bring the jeep to the garage tomorrow and dont want to fix it now.
but i know the trick trick now to let the fog lamp burn
78 chief 360amc
Old 09-23-2021, 12:31 PM
wincher's Avatar
chief has failed the TueV
rear brakes are 50% of brake power with hydraulik brake.
But brakes are similar with the parking brake.
have ask my lokal parts dealer with the AC Delco (and a few other) parts number from rockauto for order of new wheel cylinders.
Today i got the stuff and i think they dont fit because blueprint has a wrong parts finder.
he got me blueprint ADA 104402
Cherokee 1 4x4 (XJ) 1980-2001
and the engines from 2.1 diesel up to 5.9
nonsens?
looking at rockauto for a xj 1984 they are different parts numbers for the cylinder, but with excentric thread for the line..
here my parts:
https://partsfinder.bilsteingroup.co...+ 1980+-+2001
https://partsfinder.bilsteingroup.co...ortdir=asc&f=6
78 chief 360amc
Old 09-23-2021, 07:53 PM
Oooh not for sure on the part numbers but XJs are very different.
Old 09-26-2021, 01:53 AM
wincher's Avatar
rang you was right - the wheel cylinders was wrong.
(Blueprint parts finder makes a wrong selection)
have fixed the rusty old wheel cylinder and pistons with 400 sandpaper and brake grease and all is ok
doning both sides and made a test on the brake tester in the garage.
Brakepower is now good and both sides in tolerance!
and saved 35
78 chief 360amc
Old 09-26-2021, 04:56 PM
Woo hooooo!!! So much win!!
76 Chief 360/auto bolt into an 80 J10? FMSINC General FSJ Tech 14 02-17-2016 04:05 PM
1979 Jeep Cherokee Chief backfires Brody93 General FSJ Tech 9 01-23-2012 09:37 PM
4.0 swap in a 1979 Chief Pullie General FSJ Tech 25 10-28-2011 06:51 AM
Difference between chief and chief "s"? rentalrider General FSJ Discussion 2 04-22-2011 03:33 PM
1979 Baby blue Chief...SAW YOU TODAY! PlasticBoob General FSJ Discussion 0 04-17-2008 08:45 PM
