Old 08-23-2008, 09:46 PM
Jim Webb's Avatar
Jim Webb Jim Webb is offline
I need help - NP208 problem in Ohio
I have an np208 that was popping out of 4low in reverse and leaking. Today I replaced the bearings and seals and everything looked good. Now it pops of 4low in forward and reverse. I need help. I don't know what to do next. If someone is local and offer assistance I can try to offer some compensation or something I just need help before I shoot myself and the Jeep. I'm open to anything that gets the tranfercase working. Please oh please help me.
Something else that may help is if I can borrow a np208 that is known to work. Then I can see if it's my linkage or my transfercase.
Jim Webb
Columbus, Ohio
jwebb2@gmail.com
1987 Grand Wagoneer - 6" BJ's Offroad Lift kit, NP208 swap.
Old 08-24-2008, 12:07 AM
johnwaynejeep2
Posts: n/a
E-mail sent
Old 08-25-2008, 09:51 AM
Jim Webb's Avatar
BTT
Old 08-25-2008, 10:24 PM
yankeedog yankeedog is offline
Are you sure it isnt that lousy vacuum shifter thingamabob?I pitched mine and made up a linkage out of flat stock.works .maybe you can get under there and engage it manually without the vacuum motor connected .this will give you an idea if you are barking up the wrong tree ,might not be the xfer case at all might be the linkage.Just my 2 cents.
Old 08-26-2008, 05:56 PM
Jim Webb's Avatar
I removed the np229 and swapped in a np208 which doesn't use any vacuum.
Jim
Old 08-27-2008, 09:05 PM
Jim Webb's Avatar
Everything I've read on the tinternet mentions adjusting the shift linkage. I've switched my shifter to the manual transmission type that mounts on the transmission tunnel. If you look at the attached picture I'm not sure what I can adjust.
So this brings me to another questions. Is the shifter and linkage responsible for simply shifting the transfer case or shifting and holding the transfer case in gear?
Jim Webb
Old 09-01-2008, 09:32 PM
Jim Webb's Avatar
BTT
Old 09-02-2008, 09:42 AM
Chevelleguy's Avatar
The shifter only shifts the case but it has to move the lever completely. If it is not moving the t/c lever far enough, it will pop out.
In the picture there are two holes in the shifter for the rod to attach to, are you in the lowest hole?
Old 09-04-2008, 12:21 AM
Jim Blair's Avatar
Jim Blair Jim Blair is offline
If you put a body lift in, the rod won't be long enough to move all the way to low range to lock it in. Sloppy trans/motormounts will also affect it. The plastic shift fork sliders can get bent and not keep it in low range too.
Old 09-04-2008, 02:08 PM
Jim Webb's Avatar
Yes.
Old 09-04-2008, 02:09 PM
Jim Webb's Avatar
No body lift. New trans mount. And the plastic shift for pads have been replaced.
Jim
Old 01-25-2009, 08:00 PM
Jim Webb's Avatar
BTT
Old 01-25-2009, 08:41 PM
billyrb's Avatar
billyrb billyrb is offline
BJ's Off-Road
I'm voting linkage as well. Can you get any pics of the linkage from underneath? Also, did you replace the shift forks inside?
BJ's Off-Road
ryan@bjsoffroad.com
Old 01-25-2009, 10:27 PM
Jim Webb's Avatar
I did not replace the shift forks, just the shift fork pads. Also if I put the Jeep in 4low and disconnect the linkage it still pops out of low range. This leads me to believe it's not the linkage.
Jim
Old 01-26-2009, 08:30 AM
The 208 I have in the shed has a very positive detent when shifting. It would definitely hold itself in gear.
Old 01-26-2009, 11:14 AM
newtojeeps's Avatar
Could it be the detent spring or ball?
Old 01-27-2009, 08:27 PM
Jim Webb's Avatar
Good question. Does anyone know where I can buy a replacement detent spring and ball?
Thanks.
Jim
Old 01-27-2009, 08:59 PM
Agreed.
Without the linkage in place I can shift mine by hand from underneath but it's not a simple click, it takes a good effort.
I've gotten small stuff from Spencer at www.txchange.com/ like shift fork pads, but I would make sure that's the problem before ordering anything.
