  #101
Old 12-15-2021, 05:44 PM
scout4bta's Avatar
scout4bta scout4bta is offline
Have the 25 gal tank hanging on it's own. Had to drill the holes on the passenger side for the straps, the Drivers side had them in the right place. Will have to relocate the brake line for the rear axle, used that hole for the strap.
And yes there is room to remove the shocks without removing any thing else.
And there is the optional 33 gal tank if you so choose, It's 12" deep instead of 9" for the 25 gal.
Mounts for the front of the tank
The rear strap mounts.
1989 GW/91.5 Dodge W250 CTD flatbed/ 06 Ford Crown Vic Police Intercepter/05 Jeep Liberty Diesel.
Old 12-16-2021, 04:16 PM
scout4bta's Avatar
Last of the fuel tank:
[![DSCN3312_copy.jpg]
Old 12-19-2021, 12:09 PM
scout4bta's Avatar
The sending unit (sufg12A) for the chevy tank has a ohm reading of 90-94 ohm full and 0-1.5 ohm empty. If I researched correctly the SJ has a full ohm of 100-115 ohm and 0-5 ohm empty. Close enough!
Gas tank sending unit
Applications:
Blazer/Jimmy: 25 gallon Rear Mount Tank, Diesel
1984-86
CK10, 15, 20, 25, V8 379 (6.2L), w/o E.E.C.
1987
RV10, 15, 20, 25, V8 379 (6.2L), w/o E.E.C.
Suburban: 25 gallon Rear Mount Tank, Diesel
1984-86
1987
Number of lines: 3
Original Part Number: 25004087
Included with Sending Unit: Lock ring set and strainer
Packaging: Boxed
Part Number:SUFG12A
Old 01-22-2022, 03:49 PM
scout4bta's Avatar
It's been too cold for me to work in the shop untill it heats up and that's around noon if the suns out. Thats why not much progress, unlike thoses who live in the NE and put on a snow suite and continure to work in the real cold.
Back to work, kind of. 2 weeks ago I put the wagon up on ramps so I could work underneath comfortably. Got the rear axle lowered onto the ramps and the garage jack let me down. It wouldn't jack up any more, unless I used all my strength to lock the valve. Can't complain it been in use for over 40 years.
Called the company that made the jack, no repair parts, too old. But found a hydraulic jack repair company and they had the kit. The kit arrived today, so its back to work, on the garage jack.
Old 01-29-2022, 10:35 AM
scout4bta's Avatar
The floor jack is back in operation.
Next is to replace the 5/16" fuel line with 3/8" Cu Ni fuel line. Realized that the 4B has 3/8 line in and the new fuel tank has 3/8 line out, so why fight it? The return lines are all 1/4".
Old 02-10-2022, 12:02 PM
scout4bta's Avatar
My shop got up to 52℉ by late afternoon. (Too cold for me) Not getting much work done.
The weather proof relay box arrived yesterday, using them to switch the power to the trailer lights.
Factory wiring for lights is 18 awg, other than the headlights. Thanks Jeep.
Waiting on the AN fittings to arrive (this week?) for the 3/8" and 1/4" fuel lines.
Old 02-10-2022, 02:41 PM
MysticRob MysticRob is online now
Man, that's nice. You can travel all over the place with that fuel tank. Great build, really enjoy seeing this come together.
--Rob--
My build thread:
My Howell TBI Install How-To:
Old 02-11-2022, 09:41 PM
scout4bta's Avatar
Thanks MysticRob!
Old 02-19-2022, 07:57 PM
scout4bta's Avatar
Today was a good day.
Fabracated the vent tube for the rear axle and reinstalled the vent line with the factory vent cap.
The "hole" for the bolt is almost .5", the bolt is 1/4". Had to fabracate a spacer to fill the hole.
Cleaned the rear brake line and Installed the +2" rear brake line on the axle.
Removed the fuel lines and started modifiying the return. The main fuel line will be all new 3/8" CuNi (copper nickel).
scout4bta's Avatar
Fabricated the vent tube for the rear axle and reinstalled the vent line with the factory vent cap.
Installed the +2" rear brake line on the axle.The "hole" for the bolt is almost .5", the bolt is 1/4". Had to fabracate a spacer to fill the hole.
Cleaned the rear brake line.
Old 03-09-2022, 02:55 PM
scout4bta's Avatar
The fuel line(s) are in. Still need to add spiral wrap in areas that might chafe and add a few more clamps.
Old 03-12-2022, 05:36 PM
scout4bta's Avatar
Ebay wanted $21 for the fuel sending unit pigtail.
Some where internet found a connector that didn't look too bad but at $9,
no way.
So I made my own. Flattened a piece of 1/4" copper tubing around the pin size, bent it into a "S" shape, then drilled it for a #8 screw. Close enough.
Old 03-19-2022, 04:09 PM
scout4bta's Avatar
Fuel tank is in, fuel filler, vent, main fuel line and fuel tank sending unit attached, ready for fuel. Decided to use a weatherpack connector for the fuel tank sending unit connector.
I know it looks like i have stock in Ideal Clamp Manufacturing Co, But no, all the clamps are needed on the fuel filler line to be able to remove and install the tank. It's my kludge moment.
Old 04-01-2022, 07:12 PM
scout4bta's Avatar
A hole for the Air filter housing, From a Dodge Ram Diesel 94-02.
Top view:
Side:
Old 04-09-2022, 05:59 PM
scout4bta's Avatar
Ended up having to lower the floor an inch just to be sure the air box would clear the hood. Roughed in, still have some pin holes to weld up.
Old 04-10-2022, 12:01 PM
Heep-J4000's Avatar
One step at the time!
I did use the dodge ram air box to for my Cummins j4000 build.
Placed the airbox close to the front valance and cut a hole to have the intake air there.
I didn't use the jeep inner fenders but made to complete new inner fenders with a big step in them from front to back. (Still have enough wheel clearance)
Going to place the battery also above the front wheel near the firewall.
73' Jeep J4000 (named Heep or Desert Dragon) amc 360 V8 converted to LPG with T15/D20 (was my daily work truck for thirteen years and is getting major overhaul at the moment!)
80' Jeep cj5 350 V8 Chevy/sm420/D300 project
70/71 Jeep J4000 parts truck with Buick 350
Former vehicles:
Old 04-19-2022, 11:40 AM
scout4bta's Avatar
I've been brain storming the battery tray, how to support the 54 lb battery and not have it tear the sheet metal and fall through on the ground. Not having FEA (finite element analysis) at my disposal I opted for over kill from underneath. Not quite pleased with the support, came up short on the diagonal supports, literally. And I found out that I could have some tire to battery support interference. But I did remeasure the hood clearance for the battery and I have 4" from to play with. Contemplating raising the floor of the tray to move it away from the tire. I'm sure that the 2" spring lift kit will provide plenty of clearance but want to be sure.
Old 04-19-2022, 04:17 PM
That looks PERFECT. Your tire would have to be pretty stuffed up in there to get tire interference problems lifted or not...
00 Baby Cherokee
Old 04-19-2022, 09:22 PM
scout4bta's Avatar
I'm not welding the battery tray in for now just in case there is some interference later on. The "plan" is for 31x10.50 and 2" spring lift to complement the 1" body lift.
Old 04-23-2022, 05:32 PM
scout4bta's Avatar
The battery box is in and welded up, minus 3/4" off the top. Found that the the box had a slope of 1/4" left to right, and a group 34 battery would have set level with the top of the inner fender. Cut out the offending metal and welded it up.
Bad stumble on acceleration coming home last week- fixed!! Dirtball General FSJ Tech 12 04-20-2009 09:48 AM
Headed to montana...19+ hours UPDATED home with story orangebike General FSJ Discussion 11 04-12-2009 10:24 AM
Home again RiverRat Ouray FSJ Invasion 6 07-17-2007 12:53 AM
The Chero is home, and now it's running nicely... DanHS General FSJ Discussion 20 02-21-2007 07:10 PM
Tomorrow is Time to bring home my '79 Cherokee! DanHS General FSJ Discussion 23 02-14-2007 11:09 AM
