  #61
Old 06-05-2021, 10:33 AM
scout4bta's Avatar
scout4bta scout4bta is offline
Finely doing some real work towards the swap. Pulled the T Case yesterday.
Point of no return: And have a buyer for the powertrain that lives in Tucson.
1989 GW/91.5 Dodge W250 CTD flatbed/ 06 Ford Crown Vic Police Intercepter/05 Jeep Liberty Diesel.
Old 06-08-2021, 12:40 PM
scout4bta's Avatar
Just a look see to see if it's feasible. Will fit with a little trimming? The CAC is from a FreightLiner MT35 with the 4BT.
Old 06-16-2021, 06:25 PM
scout4bta's Avatar
It's gutted. Now to clean and repair. Theres some rust on the frame that needs some attention and also remove left over wiring that was for the gas motor.
Old 06-22-2021, 07:11 PM
scout4bta's Avatar
Got the transmission shifter and throttle valve cables connected at the transmission.
The trans shifter cable bracket that B&M supplied with the shifter is sorely lacking so made my own. I switched throttle valve cables from a first gen Dodge (push cable) to a second gen (pull cable).
Old 06-27-2021, 07:28 AM
scout4bta's Avatar
A change of plans, the MT35 CAC is out, I was not satisfied with the fitment. The new CAC is generic, slightly more surface area and volume than the MT35 CAC. I saw what Z&M Jeeps did and decided not to reinvent the wheel.
Old 06-27-2021, 07:29 AM
scout4bta's Avatar
The new radiator has arrived. It's for a 1975 Plymouth Duster. Slightly smaller and only 2 row but expect it to keep it cool without any problems. And it matches the Dodge accessories drive I'm using. Radiator outlet on the passenger side at bottom and radiator inlet on the drivers side top and both have the same size hose size. I'm betting that using the Dodge radiator hose with match enough that only minor trimming will be required.
Old 06-27-2021, 09:55 PM
SJTD SJTD is offline
Have you looked at an early Dodge CAC, maybe '94ish? I bought one but haven't played with it yet. Working on the interior first.
Sic friatur crustulum
Old 06-28-2021, 08:44 AM
scout4bta's Avatar
I use a first gen Dodge Diesel CAC in my Scout, but with the Scout I had access to the front of the bulkhead with the grill off. Not so with the SJ. And the 94 Dodge CAC is huge, long, wide and thick. It's not an easy fit.
The CXRacing CAC cost just under $200 with shipping.
Old 07-17-2021, 09:28 PM
scout4bta's Avatar
The hydroboost accumulator was taking up area I need for the throttle, throttle valve and the engine stop. So I rotated it 180
Old 07-20-2021, 11:08 AM
scout4bta's Avatar
Finely got the engine mount design for the frame worked out, I think. They will be bolt on using the factory mounting locations. The passenger side is relatively easy, only have to relocate the brake line and trim out a path on the fender well for the mount to slide over the frame. I still have all of the bracing to figure out, but that should be relatively easy. The drivers side not so much. 3 brake lines and 2 fuel lines will have to be rerouted. Unless I change the design the steering shaft will have to be remove to install the drivers side mount.
Setup for tac welding:
Old 07-27-2021, 09:55 PM
scout4bta's Avatar
A small milestone, have the engine resting on the frame
Theres about 1/4"-1/2" clearance between the diff and the oil pan. I think I'll be able to get by with a 2" spring lift for the additional clearance.
Old 08-10-2021, 11:24 AM
scout4bta's Avatar
The Intercooler is mounted.
Somewhat cushioned bottom mount
The top mount
Old 08-12-2021, 02:40 PM
scout4bta's Avatar
The replacement trans dipstick tube. Was able to use a 1/2" EMT tube bender to bend the 3/4" thin wall tubing with out any wrinkles.
From 94 on dodge used a "cylinder" type seal for the dipstick tube, makes it much easier to fabricate the adapter that having to make a "O" ring grove.
Old 08-14-2021, 02:58 PM
Heep-J4000's Avatar
The top mount
Can you tell what type or model intercooler you are installing?
Thanks
73' Jeep J4000 (named Heep or Desert Dragon) amc 360 V8 converted to LPG with T15/D20 (was my daily work truck for thirteen years and is getting major overhaul at the moment!)
80' Jeep cj5 350 V8 Chevy/sm420/D300 project
70/71 Jeep J4000 parts truck with Buick 350
Former vehicles:
Old 08-14-2021, 03:43 PM
scout4bta's Avatar
Thanks
It's from CXRacing, model IC0029-25.
27x11.75x3 Inch Overall Size, 3" Thickness Core, 2.5" Inlet/Outlet
Old 08-18-2021, 09:22 PM
scout4bta's Avatar
I had tried to install the engine and trans together but the engine lift didn't lift high enough and no way to tilt the combo and slide it in.
The radiator support is in the way, if I cut it out I could slide it in.
Done.
A couple of brackets to bolt it back in.
Old 08-19-2021, 08:43 AM
scout4bta's Avatar
Since I'm working by myself and I've gained 20 years since the last swap putting the engine and trans in together is so much easier. I tilted the engine/trans 25 degrees down, lifted it over the bumper, pushed it back until the trans was touching the fire wall. Lower the combo a little bit. By using hydraulic lifting table under the trans to un-tilt the combo it slides in. Lower, push in, un-tilt, repeat.
The custom trans dipstick clears the firewall
Old 09-18-2021, 01:14 PM
scout4bta's Avatar
The snowball effect.
On july 11 I ordered a 1 inch body lift kit for the wagoneer. It arrived here today. It's not a mod I take lightly. Can't find any 4x4 shops that carry 3.31 gears for the D44s. If their supplier doesn't have them, your SOL even though they exist. Shops won't put in gears not bought at the shop. So anyway I'm forced to go to 3.54 gears which means a jump in tire size which means at least a 2" spring (maybe a 1" lift?) lift to clear the front tires. And because the 4BT is a little extra heavy I might get 1.5" lift so to be on the safe side I'm adding the body lift. Of course I started taking the bolts on the body mounts, found the first one missing most of the rubber on the bottom mount. Ordered a poly body mount kit. And I found out something interesting about the Grand Wagoneer body mounts. Only the front 2 mounts under the radiator support have nuts you can access. The other 10 are caged, sandwiched in between stiffeners in the body, NO access to the nuts without cutting and welding. Luckily this is a lightly rusted car. Except for the passenger side mount if front of the rear tire. The bolt broke off, half of the of the metal was missing. Sawzall to the rescue.
Then my wife's Jeep Liberty tossed it's serpentine belt, no other damage. She ordered the parts, took a week for the tensioner and the 2 idler pulleys to arrive. Except one of the idler pulley had a notch you could feel turning the pulley. You can feel the "notch" every quarter turn of the pulley. Bad pulley.
And while I was finishing up welding the engine test stand my MillerMatic 210 quit, pushed wire, no spark. No problem pulled out the MM 130 to finish the job. It started welding intermittently. Took both into the Miller shop in Tucson friday Aug 27. Tech said he'd try to look at them before he leaves for Kanas the following monday to install a CNC plasma cutting system. The tech pulled through, picked up the welders the following monday.
And the Monsoon has finely arrived for the first time in many years. We need the rain.
Life is great, I've been taking a break from work.
Old 09-18-2021, 01:59 PM
scout4bta's Avatar
Back on track. Got the prototype throttle and throttle valve (kick down) linkage hooked up. Since I'm using the factory 94 Dodge throttle valve cable assembly I needed to make the special disk pivot that the cable hooks to. Couldn't find one for sale so made my own.
Start with a 3/8 bolt,
Welded up,
Old 09-28-2021, 12:19 PM
scout4bta's Avatar
Only had 3 body mount bolts/caged nuts rusted beyond repair. Those 3 aren't caged anymore.
The spacers were in worse shape along with the bottom washers so ended up making up new ones.
The rear body mounts had rusted out and repaired. But for the repair they added a 1/4" plate on top of the rusted hole raising the height of the body mount. Had to cut a 1/4" off of the rear body mount bushing.
Half way there. The kits don't come with hardware.
First look at the body lift installed.
Modified the dodge trans mount to fit the Jeep cross member Cut out 3 inches and welded in the new mount adapter. The Jeep frame has 2 sets of mounting holes in the frame for the cross member. The forward holds are used for the V8, the second set of holes are left over from when the Wagoneer used the inline 6, i think. The second set of holes worked out for the inline 4 and the OD trans.
Bad stumble on acceleration coming home last week- fixed!! Dirtball General FSJ Tech 12 04-20-2009 09:48 AM
Headed to montana...19+ hours UPDATED home with story orangebike General FSJ Discussion 11 04-12-2009 10:24 AM
Home again RiverRat Ouray FSJ Invasion 6 07-17-2007 12:53 AM
The Chero is home, and now it's running nicely... DanHS General FSJ Discussion 20 02-21-2007 07:10 PM
Tomorrow is Time to bring home my '79 Cherokee! DanHS General FSJ Discussion 23 02-14-2007 11:09 AM
