Old 04-30-2013, 03:38 AM
gopher_6_9 gopher_6_9 is offline
Holley analog projection.....
Ok, I have read the less than stellar reviews, however I took the plunge, I found a good priced analog projection and have the knowledge and ability to tune it. So far I have:
Complete Projection kit
Edelbrock performer intake
intake gaskets
Carb gaskets
Mounting hardware
Any other suggestions?
1983 Cherokee W/T
360
727
Old 04-30-2013, 08:32 AM
gsmikie's Avatar
gsmikie gsmikie is offline
Auto Trannie God
do you have the install video ??? i think i still have it here
Old 04-30-2013, 03:32 PM
jdaniel83's Avatar
jdaniel83 jdaniel83 is offline
I'm assuming you got the instruction manual with it, but if you didn't I believe you can download it at Holley's website. The install isn't too difficult but it is somewhat time consuming. As far as parts I believe you pretty much have it covered. You will need a hole saw (can't remember the exact size) to cut the hole in the firewall for the wiring harness to go through. And make sure you have extra splices, solder, electrical tape, or whatever you are going to use to wire it with. It's been a while since I installed it but if you have any questions let me know. Good luck.
'89 GW; 4" Susp Lift on 32" Wild Country MTX; 360, HEI, Edelbrock Intake, Melling MTA-1 Cam, Summit 600 carb, 3.73 Gears
'70 Wagoneer; stock Buick Dauntless 350, TH400; 3.73 stock gears
'83 Wagoneer Limited; stock 360, 727, 3.31 gears.
Old 05-01-2013, 03:23 AM
Sweet thanks guys. It showed up today. Good shape, ran into some problems with the axle swap today, got that situated, intake will be here tomorrow, but between work it may be next week before I get started.
No install video, but I do have the manuel. I honestly think the manuel will be enough. This looks way easier than the megasquirt I built for the 92 Rx-7 Turbo that I had.... defiantly more time consuming to tune, but easier install.
as far as tools, Should have everything, bit of a tool junkie.... just finding it. Just moved still getting garage set up.
Wiring was my specialty when I worked at a dealership.
I will keep you updated. Will start a build thread soon as well.
1983 Cherokee W/T
360
727
Old 05-01-2013, 03:29 AM
[s]One thought that came to mind. I have the edelbrock gaskets, standard gaskets..... is the factory valley pan type gasket really that much better or will I be ok using the edelbrock gaskets?[/s]
After more research I am using the valley pan and gaskets to block exhaust crossover.
1983 Cherokee W/T
360
727
Old 05-02-2013, 06:12 PM
Just bolt it up and test for gas leaks, then have someone crank the engine while you adjust the Throttle Position Sensor up and down until it runs smoothly at idle.
Make the fuel pressure between 11-13 PSI... let her warm up.
Then set the knobs on the analog ECU to mid range and readjust the throttle position sender until you can blip the engine without dying.
Follow the initial set up instructions to set the Mid Range FIRST!!!
This is critical as all other knobs work from this starting point.
Some additional details to ponder... scroll down to read.
http://www.ifsja.org/forums/vb/showt...ey+Pro-Jection
Old 05-04-2013, 06:12 AM
Absolutely Joe. Already have that printed and going to go by it. Hope to get to start on it Tuesday.
1983 Cherokee W/T
360
727
Old 05-04-2013, 06:36 PM
Does it have the O2 sensor or is it Gen 1?
Old 05-08-2013, 01:18 AM
early, trying to locate the 02 add on, but they are hard to come by for the early gen....
1983 Cherokee W/T
360
727
What do you know about a Holley projection serehill Off-Road FSJ Tech 10 09-21-2011 10:34 AM
Anyone have the Analog Holley Projection Manual ??? Greg Taylor General FSJ Tech 5 09-22-2009 04:25 PM
Holley Projection Tuning jeeprunner81 Off-Road FSJ Tech 9 06-03-2007 09:03 AM
Holley Projection /fuel pump/ electric relay problem will e General FSJ Tech 6 09-27-2006 12:16 PM
Holley Projection system vs a good Holley carb Geoffrey General FSJ Tech 17 03-11-2003 03:02 PM
