Old 03-09-2013, 09:41 AM
cheiler's Avatar
cheiler cheiler is offline
Electrical gremlins
So I'm driving along in the 88' waggy and I notice the radio has stopped working. A quick look at the voltmeter shows we're down around 8 the headlights are also out and upon restart I hear what I think is one of the two circuit breakers tripping. Help?
Chris
Old 03-09-2013, 12:48 PM
Start with the basics...
Check battery cables, check alt. belt tension and wiring.
Swing into a parts store or repair shop and have the system tested.
Good ones will do it free of charge.
Old 03-09-2013, 01:08 PM
csuengr's Avatar
csuengr csuengr is offline
Fusible link between alternator and battery.
If at first you don't succeed, use a bigger hammer.
Old 03-09-2013, 01:30 PM
cheiler's Avatar
Thank you all, I checked the fusable links all good. I'm going to take it to a mechanic. I suspect a problem with the alternator but the headlights and radio going away suggests something bigger.
Chris
Old 03-09-2013, 01:57 PM
I'm electron impaired for electrickery diagnostics but I'd start with checking that all related grounds are clean and tight.
Old 04-14-2013, 12:35 PM
cheiler's Avatar
Alternator checked out fine... going to go looking for bad grounds...
Chris
Old 04-14-2013, 12:53 PM
Quick test. With the motor running and lights on, take jumper cables (careful of the fan!) and jumper from the battery negative to the rad support or metal on the grill. If the lights get brighter, you found the problem!
Old 04-14-2013, 05:16 PM
[quote=cheiler]Alternator checked out fine... going to go looking for bad grounds...[/QUOTE
Try this procedure...
http://oljeep.com/AltTheory17/AlternatorTheoryVersion17R1.htm#Testing_Alternator s
Old 04-15-2013, 09:54 AM
cheiler's Avatar
I had the alternator tested 14.7v output. put it back in and cleaned connections and battery terminals. no change. dash voltmeter shows 10and dropping. Headlights still will not light and still no radio. tried new 30a circuit breaker no change. I'll give the other tests a try.
Chris
Old 04-15-2013, 09:56 AM
cheiler's Avatar
No lights, they no longer come on.
Chris
Old 04-15-2013, 03:00 PM
On the side plug for the alternator, there are 2 wires. One will be always live and the other will go on/off with key and have lower voltage (it passes through a 10 ohm resistor) If that one doesn't get power, the alt won't engage.
Old 04-15-2013, 04:50 PM
serehill serehill is offline
Gone,Never Forgotten.
Nope
Not the alternator plug. Maybe the firewall plug or the splice under the dash where the big red wire connects from the alternator. Next in line would be all grounds. from the battery to the firewall.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 04-15-2013, 07:57 PM
I was going to say if there are no headlights, the splice melted. Try a thick jumper wire from the back of the alt main terminal to the battery +
Old 04-26-2013, 03:56 PM
cheiler's Avatar
The plug at the alternator was gone when we bought her. it's just two wires now. I'll check the splices.
Chris
Old 04-26-2013, 07:14 PM
xGROMx's Avatar
xGROMx xGROMx is offline
sounds like the engine is getting a ground and the body is not.
Anthony@mindbreaking.com
"A Truck is Only Powerful as its Driver"
85 Waggon - SOA+Shackle Flip - OnBoardAir
Old 04-28-2013, 04:15 PM
aatcman's Avatar
aatcman aatcman is offline
You probably have 1 of 3 problems.
1. Your grounds need to be replaced.
--I ran one directly from the battery to the engine block and another directly from the battery to the body. My grounds work great now!!
2. Your alternator plug is poorly spliced. They sell replacement plugs in the help section of the autoparts stores..
3. There is another fusible link in the cable between the alternator and the battery. Even though it checks good with an ohm meter, it could still be bad. Old fusible links are prone to this -- high charging current heats up a mostly burned up link increasing the resistance and prevents the charge from getting to the battery. I cut mine out and replaced it with a 100 amp fuse...
If you want some hands on help with this, PM me.
I am quite good at electrical/electronic repairs and I am only a few miles from you..
Hope this helps
Just my 2 Cents (Good grief!! Even my weedeater laughs at me now!! Silly gas prices!)
1986 Grand Wagoneer (225xxx)
1988 Comanche Pioneer (215xxx)
Old 05-19-2013, 09:51 AM
cheiler's Avatar
Thank you, I may take you up on that. I'm going to recheck the fusible links and bottle some beer. I'll let you know if I need a hand with the waggy and getting some of that beer back out of the bottles.
Chris
Old 05-19-2013, 11:30 AM
cheiler's Avatar
Found a bad fusible link, have headlights back but now the engine won't turnover. hear the solenoid click but no starter... ugh
Chris
Old 05-19-2013, 11:57 AM
cheiler's Avatar
ITS RUNNING AND CHARGING THE BATTERY AND IT HAS HEADLIGHTS!!!!!
Chris
Old 05-19-2013, 12:28 PM
That's the direction I'm leaning. All the dash stuff that's grounded to the body relies on the body being well grounded to the frame which is just grounded to the chassis via the body mounts. After 25 years in MD salt slush don't expect the body mounts to still be good electrical ground connections. I've had wonky gauge, lights etc issues in the past. Remove a bolt holding something to the firewall or use an empty hole. Sand the paint off the sheetmetal and run a ground wire from the battery to the clean spot on the firewall. You don't need a battery cable size wire. A good secure piece of 08 or 10 ga is plenty. Clean tight grounds are your friends.
I got some electrical gremlins foureyes General FSJ Tech 8 04-11-2011 06:59 PM
Electrical gremlins in 1987 GW (clock + pegged oil pressure) lars667 General FSJ Tech 5 04-09-2011 07:49 AM
Dang Electrical Gremlins cajunKen General FSJ Tech 2 07-06-2008 11:26 PM
Electrical gremlins. Several questions Noticon General FSJ Tech 22 07-12-2007 07:13 PM
HELP! Electrical Gremlins kingmatt16 General FSJ Tech 1 12-31-2001 01:11 AM
