Old 11-11-2012, 12:34 AM
Wackyneer's Avatar
Wackyneer Wackyneer is offline
Is My Alternator Going Bad?
Last night I noticed that (headlights on) when I was sitting at a traffic light,the voltage dropped from ~13 well in to the red zone. When I would start driving again, the voltage would climb back up to ~13. I also noticed a sharp drop when operating the power windows.
I'm guessing that the alternator isn't adding enough juice at idle. I should probably check the electrical connections for the alternator first and go from there. The battery is less than a year old with <1,000 miles on it.
Thoughts???
'88 GW 360 V8, Almost stock (locking hubs and electric fuel pump)
Was it an omen that my '88 GW broke down 2 miles after the purchase and the tow truck broke down bringing it to my house?
Old 11-11-2012, 06:13 AM
jeepfan93's Avatar
jeepfan93 jeepfan93 is offline
Yea if you're not running a crazy stereo, lights or electric fans, sounds like it's time. I put a reman on my dad's 07 Denali, 2 months later put another in. Got it form Car Quest. I went to Advanced and got a new, not reman, for my F150 a few days later, same manufacturer.
Jeeps are Jeeps, keep Jeepin
>It's not about the ten hour drive to get the rust bucket jeep, it's about where your your going when it's done
87GW 99 Durango 5.2 drivetrain, SOA 35in Falken Wildpeak. MT rims
1997 Ram 1500 5.2 33in Falken Rocky Mounts for haulin
Old 11-11-2012, 10:51 AM
KISS. (keep it simple suckah!) How old/worn is the belt? When they lose 1/4 of their width the belt drops to the bottom of the groove and the flat bottom can't grab well.
Old 11-11-2012, 12:15 PM
Wackyneer's Avatar
All beltswere replacedwhen I bought it. There are <1000 miles on the belts.
I should point out that I have had to tighten the dual belts twice due to squealing. For some reason, they keep losing tension. I'm afraid that if I torque the belts any tighter, I'll bust the bolt. I'm now thinking Loctite.
Old 11-11-2012, 12:23 PM
WHSII's Avatar
WHSII WHSII is offline
Hack-Priss
the battery should also be tested, if it is going south, it will draw more current and when loading the system, it will show your symptoms.
Just my thoughts...
WH
Herbina 1987 Grand Wagoneer
Old 11-11-2012, 04:23 PM
Rich88's Avatar
Rich88 Rich88 is offline
Thoughts???
Besides loose belt, next thing is a diode or two could have crapped out. One way to check is put a voltmeter across the battery and put it on AC. If a diode is bad it will detect the ripple as AC. More than .5V AC means Alt ain't no good no more.
Context for the electrically challenged: An alternator really makes AC (alternating current) like what's in your house. Hence the name "alternator". But built-in diodes are used to rectify it do DC. So if diodes go bad, you'll be getting DC with an AC "ripple" and all that much less DC current available to keep battery charged.
Old 11-12-2012, 06:28 AM
leadsled01 leadsled01 is offline
If you do need to replace the alternator, don't buy a Power MAster.... When they stop working they will NOT warranty it and you will be stuck with a bad $200 alternator. I know this from experiance, times two!!!!
Old 11-13-2012, 12:54 PM
Test Procedures
Scroll down to the flow chart troubleshooting diagram for a quick guide
http://www.pirate4x4.com/tech/billavista/Wiring/Part2/pdf's/diagnostic-manual.pdf
Old 11-13-2012, 12:58 PM
serehill serehill is offline
Gone,Never Forgotten.
Hmm
Linky brokey
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 11-13-2012, 01:00 PM
RWrightPhotog's Avatar
RWrightPhotog RWrightPhotog is offline
I bought an Autozone reman alternator, no problems for about 4 months... was only like 30 to 40.
Rob
1982 Jeep Wagoneer Limited 360
1979 Jeep Cherokee 4-Door 258
1979 Jeep Cherokee Chief 360
Old 11-13-2012, 07:29 PM
Rich88's Avatar
You realize you're busting a lot of myths, opinions and "experience" now.
Old 11-13-2012, 08:45 PM
hmmm
Not really
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 11-14-2012, 02:18 PM
Like Dragnet...Just the Facts
Old 11-14-2012, 09:29 PM
Rich88's Avatar
Originally Posted by serehill
Not really
I hope you know I wasn't referring to you. If not, let it be written.
Otherwise Joe's posts ought to be stickies.
