Old 08-27-2011, 07:34 PM
scannman70's Avatar
scannman70 scannman70 is offline
1970 J2000 rebuild thread,
http://s1141.photobucket.com/albums/...eep%20rebuild/
Trying out this photobucket thing....
Old 08-27-2011, 07:40 PM
Dr. Marneaus's Avatar
360 AMC
FYI if when you hover over the picture, you select the bottom line that says IMG code, then past that, it'll show the picture in the thread.
Originally Posted by FSJunkie
The Mag - The Wag
Old 08-27-2011, 09:19 PM
360 AMC
looks nice and beefy!
However, i think your pics are too big and will be closed down.
Go to photobucket, go to the page where you upload photos, at the bottom it will say "upload options" click that, and change the upload size to 800x600
The Mag - The Wag
Old 08-27-2011, 10:01 PM
twisted frame twisted frame is offline
wild guess on what the brush guard came from: Toyota Landcruiser?
Mike
1973 J4000, 360 2bbl, T18, Model 20,
44, 60-2, 32x11.5x15" on 15x8" CJ wagon wheels.
Now in black primer.
Old 08-28-2011, 06:52 AM
scannman70's Avatar
grill guard small pic
Old 09-07-2011, 05:38 PM
scannman70's Avatar
Needed to get the front end sitting level with the rear,
Bought a set of rough country AAL off of E bay 2 inches wide 22 inches long
For a scout, for $47.98 shipped to my door.
Have these and another spring pack going to see what I can do, but keeping safety in mind first..
Also bought the U bolt flip kit on here a long time ago, so it should all go together soon.. Hopefully..
Old 09-24-2011, 05:27 PM
scannman70's Avatar
Workin on a seat
http://s1141.photobucket.com/albums/...0jeep%20truck/
So My seat was shot, actually had boards under the blanket in stead of springs.
Neighbor is re doing a 1968 Ford truck, it had 36K miles on it, he was going to throw out the stock seat, being the pack rat i am. i took it. Dug it out the other day, never thought it would fit in a jeep cab.
but it does, since it was from a 2wd truck it did not have the cut out for the 4wd hump.
Took cover off seat bottom and modified a 22 inch long section .
What a PITA getting the cover back on.
looks pretty good, need to get the brackets and mount it to the floor. and get the seat belts in.
TF 727 Rebuild Video & question leostevo General FSJ Tech 2 01-22-2011 11:53 PM
Tuned up the truck 1970 J2000 scannman70 General FSJ Discussion 5 05-07-2008 02:48 PM
Radiator in a 1970 J2000 scannman70 General FSJ Discussion 5 04-14-2008 05:32 PM
rebuild with QT to select track switch? JonM General FSJ Tech 2 01-02-2004 09:29 AM
Rebuild 360/401 v. Goodwrench 350 Chero77 General FSJ Tech 30 01-13-2003 05:44 PM
