Old 11-12-2010, 01:18 PM
fanboatman's Avatar
fanboatman fanboatman is offline
Noob!
where to get new headlight adjusters
My cherokee's headlights are shining in the ditch so I took the grill off to see whats wrong. Turns out the plastic the adjuster screws go into are stripped or broken. Does anyone know where I can find replacements? I can't seem to find any.
'79 Cherokee Golden Eagle, 360, turbo 400, quadratrac
Old 11-12-2010, 02:54 PM
palexand palexand is offline
Sometimes you can find these in the HELP! section of your parts store. Baxters in my neck of the woods has a huge selection and another off brand (can't recall the name) providing all kinds of doo-dads, and I'm certain I've seen there there - not sure if they're exactly correct though. Else, yard diving always works.
Old 11-12-2010, 03:26 PM
Bill Moore's Avatar
Bill Moore Bill Moore is offline
I believe Jaber is making them, check out the home vendor section, or pm him
DDs
67 KJ715 4bt AA OD 465 np205
78 J20 Chevy 305 nv4500 np205
Projects
Sons Build 1980 short bed J10, j20 axles, 4bt, nv4500, np205, shortened M715 bed and fenders
Freedom is not Free, it is paid for with Blood
Old 01-11-2011, 12:53 AM
Michael_King024's Avatar
Michael_King024 Michael_King024 is offline
everytime i go junking i look for these rascals but 9 times out of ten they are dryrotted and break at exactly the moment you get the beam aligned...so i devised a fix...not pretty but works like a champ...you'll needa small peice of rubber vacuum tubing, and a small plastic drywall anchor with a screw ...insert the tubing into the hole in the back shroud thingy...then insert the anchor into the tube( this expands the rubber enough to grab the hole rim...then replace the factory adjuster screw with the drywall screw and screw it in...it will expand the assembly nicely and is very snug voila!!..no more adjuster probs....ill take a pic of the one i did on my 83 and post tomorrow to show exactly what i mean..
Big Mike
83 wag limited-360-
89 G.wag -360-
"10-4 rubber duck"
"In GOD we trust..all others pay cash"
-mat. 21:42-
Old 01-11-2011, 01:11 AM
Tigger4X's Avatar
Tigger4X Tigger4X is offline
Which shape are your headlights and what kind of grill? I'm parting out an '87 Grand Wag and all must go. Check out the pics and post up if you see something you need. I can get detailed pics if you need them as well.
Originally Posted by will e
Old 01-11-2011, 01:20 AM
Thumper168's Avatar
Thumper168 Thumper168 is offline
I just went through this Friday, I removed the headlight bucket and wleded up new tabs and solved my problem forever. I couldnt find any locally so I made my own. If you have a welder and two 10-28 nuts and a 4" piece of 3/8" tubing you can fix it yourself. I bought my stuff at HD for less than $3
84 Grand Wagoneer
Old 01-11-2011, 07:37 AM
Here you go.
I still have both styles ready to mail...
Replacement head light adjusters
43 cj2a
51 Willys p/u
'51 Willys Parkway Conversion
'74 CJ5
'75 J-20 Wrecker
'75 J-20 Cummins service bed
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Old 11-20-2021, 06:00 PM
azmtn04 azmtn04 is offline
Originally Posted by jaber
Here you go.
Are you still making these?
1981 Cherokee Chief S
Old 11-21-2021, 11:43 AM
Heep-J4000's Avatar
I would say that he still does.
He has also a ad on eBay with the headlight adjusters
73' Jeep J4000 (named Heep or Desert Dragon) amc 360 V8 converted to LPG with T15/D20 (was my daily work truck for thirteen years and is getting major overhaul at the moment!)
80' Jeep cj5 350 V8 Chevy/sm420/D300 project
70/71 Jeep J4000 parts truck with Buick 350
Former vehicles:
Old 11-21-2021, 06:23 PM
Yes I do.
74-78 round bulbs-
https://www.ebay.com/itm/1974-1978-J...IAAOSwqLRcI-DL
79-91 rectangle bulbs-
https://www.ebay.com/itm/114781837226
43 cj2a
51 Willys p/u
'74 CJ5
'75 J-20 Wrecker
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Headlight Adjusters SkylinePCG General FSJ Discussion 7 10-26-2010 07:48 AM
Driver's side headlight low beam keeps burning out DanHS General FSJ Tech 8 01-05-2009 09:39 PM
Headlight adjusters? rreed General FSJ Tech 7 08-18-2008 08:25 PM
Need headlight adjusters!! Chrome General FSJ Tech 2 05-05-2008 07:50 AM
Headlight Upgrade. H4 and Relays Mahamotorworks General FSJ Tech 3 12-09-2007 12:18 AM
