Old 12-29-2009, 12:02 PM
CasualGourmet's Avatar
CasualGourmet CasualGourmet is offline
MC2150 Vacuum Line
Does anyone have a diagrahm for what the correct vacuum line hook ups are? Thanks!!
Let me rephrase that, one that works without the smog pump
Old 12-29-2009, 12:28 PM
brad_fsj10's Avatar
brad_fsj10 brad_fsj10 is offline
I posted the link to the best vacuum diagrams around yesterday...
Remove the T-fitting between the manifold vacuum source and the air pump, and route the vacuum line from the mainfold vacuum source directly to the top port on the CTO valve...
Brad Smith
79 J20
360/NV4500
D44/D60/3.31s
past rigs -
86 J10
80 J10
79 Chief
Old 12-29-2009, 12:30 PM
dbuie dbuie is offline
Smog pump or Charcoal canister? On my '89 my smog pump hose goes to my air diverter valve and then based on engine temps, air is routed to the manifolds/cat. There are two valves on the diverter assembly. The top gets manifold vacuum and the bottom one is connected to a dual CTO on the back of the manifold. I have no vacuum lines from the carb going to the smog pump. The charcoal canister does have lines connected to the carb however.
1989 GW-Resto Project
My "Labor of Love"
