Old 03-24-2012, 04:54 PM
68glad's Avatar
68glad 68glad is offline
D60 carnage
Had a little carnage last weekend in the snow. Thought I'd share.
EDIT: Oh, here's how deep it got. : )
Ordered some 35 spline shafts & hubs. Anyone know if this snapring comes w/ the hubs? They're Milemarker 459SS. Some like them....some don't.
68 gladiator- 455/400/20 r.i.p.
78 wagoneer- 401, drw60, drw70, 203/205, 38's, oba, obw, hydroboost, dual p/s pump, bla bla bla
Old 03-24-2012, 05:02 PM
Stuka's Avatar
Stuka Stuka is offline
Not sure if Mile Markers come with the snap ring or not. Thats an interesting place for the shaft to fail though. I don't think I have seen one break like that before.
Is that a DRW front axle?
Old 03-24-2012, 07:48 PM
68glad's Avatar
Yes it is. When it broke, the shaft also swelled the threaded end of the spindle. I had to cut 4 relief cuts in the end of it just to get the two jam nuts off. Pic only has two though. New spindle on order too if one don't show up in my wanted thread.
Old 03-24-2012, 08:55 PM
Blake Blake is offline
When I was running those MM lockout hubs, I didn't use those snap rings on my D60. I've since switched over to spicer lockouts because I kept breaking the MM lockouts.
I broke my D60 in the same exact spot. The earlier shafts neck down towards the ujoint and are prone to failing. Replaced it with some shafts that don't neck down.
I welded mine back together and put some DOM tubing around it for a trail spare.
Old 03-25-2012, 08:44 AM
Sambo's Avatar
Sambo Sambo is offline
ford d60s use that style of "flat"ring. my stock dodge60 used the round style not the flat.altho both work in my hub!
77 chero DEAD.
Old 03-25-2012, 10:18 AM
jeeping1974's Avatar
That is some deep snow!
03 GMC 2500HD - DD/toy hauler
06 Street Glide - Cruiser
Old 03-25-2012, 04:24 PM
AlsChopShop's Avatar
if the snow is over your hood, its too deep.
Al
14b or D60 rear Hippie Metal Off-Road FSJ Tech 39 08-20-2010 02:10 PM
Disk brake upgrade on Jeep D60 J10Mike Off-Road FSJ Tech 19 05-23-2006 07:57 AM
Need J20 D60 help BillyBob535 General FSJ Tech 11 02-25-2004 01:09 AM
