  #41
Old 01-28-2008, 05:29 PM
TAN79's Avatar
TAN79 TAN79 is offline
truck is a 79 wt cherokee with bjs 6 in lift and 1in shackles in the front. its got 35x14.50 boggers on 15x10 rims. i did cut the fenders for added clearance mostly cause of the rear.
Old 02-09-2008, 04:05 AM
jeeping1974's Avatar
79 golden eagle
33x9.5x15
stock wheels
no lift
no trimming
03 GMC 2500HD - DD/toy hauler
06 Street Glide - Cruiser
Old 02-09-2008, 11:04 AM
El Jefe's Avatar
El Jefe El Jefe is offline
4" lift, black diamond front springs, skyjacker rear. 315/75R16 hi tec retreads on cheapy 16x8 rims. trimmed a little off the front corner of the front fenders.
Alex
76 Cherokee Chief
350/th400/d20
d44/14b
4" lift, 35 inch retreads
Old 02-17-2008, 11:23 PM
BIK's Avatar
BIK BIK is offline
Lift
Here is my 91 waggy with the BJ's 6" all spring lift and some 33x12.5 trxus mts on 10" wide steel wheels. I trimmed 1"+ out of the rear fenders, filled the gap with silcone, and covered it with plastic trim. No rubbing at full stuff.
91 Waggy, Runs, Lifted, 33"s.
Old 02-19-2008, 05:21 PM
dakotajeep's Avatar
dakotajeep dakotajeep is offline
79 WAG
2" Front shackle/2" Rear block
Stock wheels and tires
Rust is the only trim featured
I got pissed seeing these pics.....she's gone.....
My 81 is in the background.
1981 Wagoneer (parting out if interested)
Working engine and tranny
2'' AAL (been vandalized)
1979 Wagoneer (sold)
2" Shackles up front and 2" blocks in the rear
Dana 44's with 3.07's from a 77 Wag
Old 02-24-2008, 11:54 PM
bigred2004's Avatar
bigred2004 bigred2004 is offline
38.5x15.50x15 SSRs on 15x10s
Estimated 16-18" lift from stock(measured with stock 30s)
Front: 4" springs, SOA, 4" custom shackle reversal
Rear: 10" custom shackle flip, 2" shackles, 3" blocks(temporarily)
Old 03-24-2008, 03:32 PM
Adam17's Avatar
Adam17 Adam17 is offline
1986 Jeep Grand Wag
133K Miles 360/TF727/NP228 A
militaryjeepers.com
coastalcarolinaoffroad.com
Old 03-30-2008, 07:30 PM
tinnmann31's Avatar
tinnmann31 tinnmann31 is offline
BFG 33 x 12.5 x r15 mudkings, no lift
<a href="http://s270.photobucket.com/albums/j...rrent=j-10.jpg"
David V.
'81 J-10 Laredo AMC 304 v8 727 tf trans
np 208 t-case 33" mud kings
"The government cannot give to anyone anything that it does not first take from someone else."
Every man has a 6 pack, just some of us chose to carry it in one container.
Old 03-30-2008, 07:37 PM
Stuka's Avatar
Stuka Stuka is offline
1981 J10
33x12.50 Interco TSL's (measure 34" tall)
15x8 K10 Rally Wheels
6" Spring Lift
Tires rub in back
Full Size Jeep Network
1975 Cherokee *Sold*
1989 XJ Limited *Sold*
Old 03-30-2008, 09:47 PM
69 Gladiator's Avatar
69 Gladiator 69 Gladiator is offline
'69 J-3000. 15 X 8 spokes with 4.5 BS. Q Buckshots. 3" body. re-arched + 2 heavy leaves in the front gained 5" over what it was , it was sagging pretty bad, so it is most likely 4" over stock. Rear shackle flip . Very little trimming. And yes , what I do with it , it will rub a bit when worked out. Nothing major.
http://i246.photobucket.com/albums/g...March08092.jpg
'69 J-3000 Gladiator
'78 Olds 403 powerplant
Turbo 400 W/Transgo-TH2 shift kit
Dana 20 TC
D44 front
D53 rear
4.09s
8 inch lift
Q Buckshots
Bad Boy
Old 04-01-2008, 04:56 PM
Ghinmi's Avatar
Ghinmi Ghinmi is offline
Super Moderator
Bj's 6" lift with 33x12.50 on 15x8's. No rubbing and no trimming.
Stock height front, rear 1-1.5" lift (1979 springs), 28" tires on stock 15x7 rims.
Old 04-09-2008, 05:37 PM
irmosc's Avatar
irmosc irmosc is offline
1990 Grand Wagoneer
31"x10.50 BFG A/T KO
15x8 Factory Rims
2" Rancho 44044 front / 2" BJ's springs rear
1976 CJ7 - 360/TH400/Quad
1990 Grand Wagoneer - Luxury Wagon
1979 Wagoneer - QT and all
1984 Grand Wagoneer - Sold
http://picasaweb.google.com/irmosc
Old 04-09-2008, 06:48 PM
shimniok's Avatar
shimniok shimniok is offline
Troubled Child pics
2002 Ouray with rear fender trimming, no front trim:
On the ramp, before front fender trimming
Recent photo from 2008, all fenders trimmed:
Tire Size and Make:
33x12.50-15 Goodyear Wrangler MT/R
Rim Size and Make: 15"x8" Rock Crawler steel rims
How Much Lift: 4"
What Type of Lift: Skyjacker, all spring, purchased 1999
If you had to trim your Wheel Openings: Rear 2", front 2" due to Cherokee WT axles installed
More details here
Michael
Old 04-26-2008, 06:14 PM
Chris Barry's Avatar
Chris Barry Chris Barry is offline
'85 Grand Waggy
Tire Size and Make:33X12.5R15 no name
Rim Size and Make:stock waggy rims
How Much Lift:4inch
What Type of LiftBJ's all spring 2 inch and BJ's 2inch body lift
If you had to trim your Wheel Openings:Nope
A photo from the side so people can see what it looks like.
'79 Cherokee Chief
Tire Size and Make:31X10.5R15 no name
Rim Size and Make:stock white spoke cherokee rims
How Much Lift:none
What Type of Lift:N/A
Tire Size and Make:stock tires
Rim Size and Make:stock rims
How Much Lift:none
Hope that all helps
'85 Grand Waggy 360/727/NP229 33X12.5R15 2inch susp lift with 2inch body lift.(wife's DD)
'86 Grand Waggy all stock with custom sagging springs
'85 Baby Cherokee 2.5L(my new DD)
'89 Chevy K2500 flatbed
'87 Ford Ranger
'84 Renault LeCar
'84 Honda Passport
'66 Yamaha MG-1T
http://www.jpricefamily.org/joy/Chris-Cars.htm
Old 04-27-2008, 12:39 PM
-Bluegill-'s Avatar
-Bluegill- -Bluegill- is offline
Tire Size and Make 35x12.50 Baja Claw radial
Rim Size and Make stock 15x8 steel wagons, with 1.5" billet spacers
How Much Lift 6.75"
What Type of Lift TT's SOA & shackle flip
If you had to trim your Wheel Openings No
Tire Size and Make 36x13.50 IROK bias
Rim Size and Make 15x10 steel wagons, 3.625" backspace
How Much Lift 6.75" F, 7.75" R
What Type of Lift TT's SOA & shackle flip, 1" shackles in rear
If you had to trim your Wheel Openings Yes
Sorry, don't have a better side shot of it yet. Now that I've added 230lbs of bumper & winch to the front, the front springs seem to sag a little more each time I drive it, so the front is slated for 1.5" add-a-leafs soon.
Old 04-29-2008, 10:07 PM
Heimeken's Avatar
Heimeken Heimeken is offline
Tires 38x16.5x15.5 Parenelli Jones Dirt Grips
Wheels 16.5x9.75 Modular steel
Front Lift - SOA+Rancho 4044+3" body = 11"
Rear Lift -Shackle Flip + 3" custom springs + 3" body = 11"
Bushwacker cutouts
401, NV4500, 3/4 ton gear
'79 Cherokee "The Sandgorgon"
One Tons, SOA,T18 on 40's
78 J10 "Imoteb"
J20 running gear and axles
Old 05-02-2008, 02:28 PM
wojo's Avatar
wojo wojo is offline
82 WT Cherokee
BJ's 6" lift
35" x 12.50 BFG MT's
No trimming
White Wagon Wheels
Old 05-05-2008, 05:55 AM
sungoesdown's Avatar
sungoesdown sungoesdown is offline
33" tires(used)
15" stock rim
3" body lift
total investment on tires and lift-$175
83 j-10
86 grand wagoneer
Originally Posted by HeadHoncho
BTW, how does someone from Iran have a BJ's Offroad sticker but I can't seem to get one sent to New Jersey?????!!!!!!!
Originally Posted by holley2346
I hated to hear this as I was really wanting to do an ox in the rear.
Old 05-11-2008, 04:19 PM
63fordf100's Avatar
63fordf100 63fordf100 is offline
hey guys im pretty new to the site, hence the no pic yet. i have a question as far as tire sizes. i got a set of old 31x10.50's ond 15x8 chevy rims from a friend. they fit great no rub or anything. my question is.... would i be able to stuff 32" tires on same rims on my 88 grand wagoneer with any rubbing or would that be too much tire? i would like to lift but since i cant afford that yet i was looking for decent ground clearance via bigger tires. future plans include SOA, shackle flip with 1" block(make up for wag sag) and just enough fender trimming to fit 37's. still working on ideas for motor, lol. thanks for any info you can come up with. this site is awesome with the amounts of ideas and helpful people. thanks again..... brandon
Old 05-22-2008, 11:09 PM
JACMAN JACMAN is offline
Brandon -
You should be able to get 32" in; however, you may have to trim a little at the front dependent on what you want to do with the truck. If you are driving around town, you should not have any problem, but trail riding may be a different story! For about $250 and a Saturday, you could fix it up nice if you want to get out cheap.
