Old 06-18-2007, 09:19 PM
uglyjeepling's Avatar
uglyjeepling uglyjeepling is offline
Unhappy Manual Rear Window Crank Problem
I got the manual rear window crank from BJ's and i can get the key tumbler in correctly Just to make it work a little i had to grind down portions, just to get it locked in. Now i got it in and it needs a little more grinding so the outside flip door closes but its stuck inside. I even used a poker to push in the lock. I need to know if anyone has had problem installing the lock tumbler into the manual crank. The one that came with it is definitely not working.
Matt 'Captain 'insert new stupid thing I did here''
"H2's are like sphincters, they're all crappy...and now Chinese."
'79 WT Cherokee, Black Stock Rims, BJ's Aluminum Radiator, 31" Firestone Destination M/T, PowerTrax No-Slip Locker, Hurculined passenger area, Holley Electronic Fuel Pump, TFI!!
'64 Mercury Comet Cyclone. Stock.
Old 06-18-2007, 09:54 PM
Matt, you may want to also pose this question in the vendor forum or on the forum at BJs Offroad site.
Old 06-20-2007, 10:39 AM
I got the lock cylinder out of the handle. I used a small allen to release the retainer, wire doesnt work. I had to grind down the end of the cylinder to fit the thing in. It was too long and was bottoming out not allowing the retainer to engage, allow it to turn or allow the top to go in enough to close the flip cover. All in all the cylinder that was sent was not right and made the job 10 times as hard as it should of been.
Old 06-20-2007, 10:52 AM
billyrb's Avatar
billyrb billyrb is offline
BJ's Off-Road
I never saw an email about this (nor a call). Did you call or email someone else at our company about it?
BJ's Off-Road
ryan@bjsoffroad.com
Old 06-20-2007, 11:35 AM
PM'd you.
