View Poll Results: Will an engine over heat without a thermostat?
Nope! It will never reach operating temp 15 88.24%
Yes! Don't do it! You will over heat! 2 11.76%
Voters: 17. You may not vote on this poll
Old 03-09-2021, 09:04 AM
J20 project's Avatar
All things being said Ristow is right...hmmm think about that.
if your cooling system can keep the engine cool with a thermostat,it will keep it cool without.
Personally after having spent 30 yrs involved with cooling towers and relative flow of about 6000gpm, transferring heat into the water was very easy...getting it out was another thing. Still very dependent on flowrates and dewpoint(affected a lot by humidity). Many times we did a better job through the tower(radiator) buy slowing the flow down rather than just speeding it up.
More tower cells(rows/fins) tended to manage the amount of cooling drastically. When took a tower cell down for cleaning and ran 3/4 of the system...we just plain had to limit the amount of flow...hence the idea that a bigger, better radiator does more work(heat transfer) with the same flow.
J20
BP Drivetrain...........
775-537-7918
Old 03-09-2021, 03:32 PM
The thermostat keeps the engine warm. Its gonna run cool with ot removed. Go talk to anyone thats had a thermostat stick open on a big diesel. It ran cool.
Old 03-10-2021, 08:58 AM
And to your earlier point Ristow, the diesel rigs cooling system is built to handle lotsa heat transfer. It would be interesting to run the simulations to include egt...
The cummins diesels I have had were built w/ programming to heat up is too cool at idle. The egt is directly proportional to how much boost is going on as well as the ambient temp on my truck.
J20
775-537-7918
Old 03-10-2021, 12:07 PM
now,i do believe the slight pressure that the water pump makes in the block due to the restriction of the closed thermostat does enhance the recirculation of the coolant thru the bypass system. without the thermostat you may see elevated temps depending on block design,and where the temp sender is.
but not overheating,and certainly not runaway overheating.
Old 03-10-2021, 12:08 PM
sweet merciful crap! fix those huge images!!
Old 03-10-2021, 01:26 PM
lol
Old 03-13-2021, 10:19 AM
Heep-J4000's Avatar
https://www.onallcylinders.com/2016/...to-avoid-them/
Trucks/car's from the past:
Old 03-13-2021, 11:18 AM
SJTD SJTD is offline
What're you saying there Heep?
Since it said it on a flashy web page it's true?
Or are you thinking all the posts refuting what the author wrote had it correct?
Sic friatur crustulum
Old 03-13-2021, 11:22 AM
J20
Nobody's saying that running more radiator won't cool better though the coolant velocity is lower.
Old 03-13-2021, 11:47 AM
I just broke my axle and will not be able to fix it until I get home from a 6 week business trip. I won't be able to run this until mid May.
Old 03-13-2021, 12:38 PM
Heep-J4000's Avatar
Just came across the article while searching for a alloy radiator to fit in front of a 12 valve Cummins and put it in my J-4000
Engine build ( a learning thread) Chief Gunner General FSJ Discussion 12 11-20-2012 06:01 PM
termostat help Poley General FSJ Tech 4 05-11-2004 04:54 PM
Need Expert Advice On Engine Rebuild!! Rompn General FSJ Tech 7 12-31-2003 09:45 AM
Help please Dan G General FSJ Tech 36 09-02-2002 08:47 AM
Thermostat Puslinch Engine 0 08-14-2000 06:27 AM
