Old 05-11-2020, 03:41 PM
Bullywerks Bullywerks is offline
1986 GW tailgate glass installation problems
I bought a new lift bar and side channels for my 86 Grand Wagoneer's tailgate glass. The kit comes with the roll of seal that holds the glass in place. But the stuff is so thin. The lift bar just slides on and does not grip or hold the glass. Is there something else to installing the bar on the glass that i'm missing ?
Old 05-11-2020, 05:48 PM
levelhead's Avatar
levelhead levelhead is offline
I use auto glass urethane to install glass to channel
1988 GW (2)
1980 Cherokee Laredo
1979 Wagoneer
1976 J10 401
1977 Wagoneer 401
1977 J10 4 speed
1969 J3000 (2)
1955 CJ3B
Old 05-11-2020, 10:03 PM
SJTD SJTD is offline
That or the strip of rubber the vendors sell. You fold it over the edge an seat the channel with a hammer and block of wood.
Sic friatur crustulum
Old 05-12-2020, 09:52 AM
chubbinius's Avatar
If I remember from other threads correctly, there are different thicknesses to the tailgate glass between older and newer ones. BJ's carries both older and newer style rubber tailgate window lifter seals. It's possible you have a thinner tailgate glass that needs the thicker seal. You can check them out here and always give BJ's a ring
https://www.bjsoffroad.com/search.asp?keyword=tailgate+window+lifter+seal&sea rch=
Hope that helps!
1970 1414X Wagoneer "The Pig"
-Dauntless 350 V8
-D27 front/D44 rear
2006 XK (65th Ann Edition)-DD
Old 05-14-2020, 11:29 AM
Hope that helps!
Correct! 79 was the change over year. <79 was thick, >79 was thin. Here are the differences in side windows. The differences in the rubber was only in the gasket thingey that goes into the lift bar. The scrapers and channels are all the same, I think.
The lower, thicker window is from a 78 Cherokee and the upper thinner window is from my 79. Both are driver side door windows. My understanding is all windows (except 2 door Cherokee rear side windows) got thinner in 79.
Replacement Tailgate Glass Question asudchiman General FSJ Tech 12 10-22-2016 02:43 PM
lights, turn signals, tailgate, blower motor problems scottg Build Threads 2 12-29-2015 08:59 PM
'90 GW Tailgate Glass ? stonehengeheels General FSJ Tech 4 07-20-2014 04:37 AM
Tailgate glass channels inside gate, can you get them? Kaiserjeeps General FSJ Tech 6 09-22-2003 01:01 PM
tailgate window problems leila General FSJ Tech 1 08-06-2002 09:02 AM
