Old 07-26-2020, 05:27 PM
scout4bta's Avatar
scout4bta scout4bta is offline
Changing out the Turbocharger
Changing out the turbocharger
1989 GW/91.5 Dodge W250 CTD flatbed/ 06 Ford Crown Vic Police Intercepter/05 Jeep Liberty Diesel.
Old 08-07-2020, 10:22 AM
scout4bta's Avatar
Update: thermostat housing selection.
Old 08-27-2020, 10:19 AM
scout4bta's Avatar
Update: Fabricating the turbo drain.
Old 10-02-2020, 08:25 AM
scout4bta's Avatar
Revised Turbo Drain and first mock up of engine mounts.
Old 11-21-2020, 09:36 PM
scout4bta's Avatar
Unfortunately any further Wagoneer upgrades are going to have to wait, probably until the end of next March. The wife's Jeep Liberty suspension parts were 2 months late, the CVPI had a unfortunate accident which I'm in the middle of fixing so her jeep didn't get it's fix. And the wife is in her 4th of 12 courses of chemo which is taking a toll on her. Were having to spend every other week at the clinic 80 miles from home for the chemo sessions. They have a guest house were staying at, it's nice but it's not home.
The Wagoneer will get done only later.
Old 11-29-2020, 05:27 AM
xjranger2003's Avatar
xjranger2003 xjranger2003 is offline
Sorry to hear about your wife. I'll pray for you both.
Old 11-29-2020, 04:34 PM
scout4bta's Avatar
Thank you.
My wife is doing good, she's a fighter.
Old 12-25-2020, 06:32 PM
Mikel's Avatar
Mikel Mikel is offline
Glad to hear she's doing better.
1969 M715 6x6
1963 J300 Swivel frame
Old 12-29-2020, 06:31 AM
scout4bta's Avatar
Red face
Thank you!
The other good news because of the holiday's she gets a 3 week reprieve from the chemo cycles.
Old 02-15-2021, 11:18 AM
scout4bta's Avatar
Update: T case problem.
Old 03-12-2021, 08:18 PM
Tigger4X's Avatar
Tigger4X Tigger4X is offline
SUBSCRIBED
Many 🙏🏻🙏🏻 for your wife and yourself as well!
Originally Posted by will e
Old 03-13-2021, 09:11 AM
scout4bta's Avatar
Originally Posted by Tigger4X
SUBSCRIBED
Many �������� for your wife and yourself as well!
Thanks.
Good news! MY wife has been declared Cancer free (for now) and soon (very soon) I'll be pulling the GW into the shop.
Old 03-13-2021, 11:28 AM
SJTD SJTD is offline
Great news! Glad to hear it.
Sic friatur crustulum
Old 03-13-2021, 03:24 PM
Tigger4X's Avatar
Originally Posted by scout4bta
Thanks.
That is HUGE! PTL!! He is good, all the time! Will keep praying
Looking forward to your updates on the GW
Old 04-16-2021, 08:15 AM
scout4bta's Avatar
Progress!
Found a "free" pic posting site, will see how this works: https://postimg.cc.
The swap is on.
Attached the trans to the engine for a preliminary look see. When the bolts that attach the flex plate to the crankshaft arrive I'll assemble the trans to the engine again, start it up and run it to completely fill the trans and run it thru the gears to make sure it works. What could go wrong?
Looks like the trans dip stick might me in the way of the exhaust. I'm trying to keep the engine as close to the firewall as possibly. Jegs makes a 30" flexible dip stick that could replace the factory one. And there is the HVAC box on the firewall that might be in the way.
Old 04-16-2021, 07:02 PM
Tigger4X's Avatar
Man that is looking really good
Is that trans an OD unit? The set up on my truck is sorely lacking and I'm having one heckuva time finding a way to get my divorced US Gear OD to engage; the control module and switch are gone. An OD trans would make a world of difference over the T-18.
Pardon the question, but the Atlas isn't in the pic, right? I couldn't afford one so I'd have to find a t-case that works with the OD trans. Trying to find an NV4500 much less an NV5600 and a t-case is either a kidney and a half or nonexistent.
All in all, my rambling done, I am green with envy and can't wait to see how it comes along! Have a great weekend!
Old 04-16-2021, 08:10 PM
scout4bta's Avatar
Is that trans an OD unit? (edit..) An OD trans would make a world of difference over the T-18.
It's a A518/46RH from a 92 Dodge Diesel, has an OD but it doesn't have a lock up torque converter.
The Atlas T case is just out of the picture on the Left.
When I do the run in I plan on attaching the Atlas. Will probably need a support to keep if from tipping.
Old 04-21-2021, 05:38 PM
scout4bta's Avatar
One of my objectives is to mount the engine as high as possible so as to use the least amount of spring lift to clear the front axle. I'd milled the heater grid down as far as I could to make that happen. Then I noticed that the air horn on my 91.5 Dodge W250 sits lower (3/4") than the froward facing air horn that came with the 4BT. Only problem is now the heater grid now sets too low for the new air horn. No problem I'll just weld the cut off piece on to the the new air horn.
Only 3rd time using the mig spool gun. Ugly welds. So the engine can sit 1/2" higher.
Old 04-22-2021, 08:53 PM
scout4bta's Avatar
Upgraded the alternator with a internal voltage regulator, 1N8315 from Apswholesale.com
This alt is from Dodge/Cummins Diesel which is controlled by a ECU. No ECU on this Wagon.
Once in the wagon connect switched voltage to the orange wire and I'm in business.
Old 05-01-2021, 05:37 PM
scout4bta's Avatar
Electrical problems. Need a connector for the OD solenoid. Don't have salvage yards within 2 hrs drive so that's out.
No luck on finding a pigtail on the internet. Least not at a reasonable price. P.A.C.T. sells one for $49.00 plus shipping. I am not going to spend that much on one. Persuaded my wife to help in the internet search. She's and expert at researching, Nothing.
Plan 2, bought one (echlin EC11) that looked close enough and modified it to fit. This is just the prototype.
The fun part will be making it weatherproof.
Bad stumble on acceleration coming home last week- fixed!! Dirtball General FSJ Tech 12 04-20-2009 09:48 AM
Headed to montana...19+ hours UPDATED home with story orangebike General FSJ Discussion 11 04-12-2009 10:24 AM
Home again RiverRat Ouray FSJ Invasion 6 07-17-2007 12:53 AM
The Chero is home, and now it's running nicely... DanHS General FSJ Discussion 20 02-21-2007 07:10 PM
Tomorrow is Time to bring home my '79 Cherokee! DanHS General FSJ Discussion 23 02-14-2007 11:09 AM
