Old 05-09-2010, 08:24 AM
Chris Langdon's Avatar
Chris Langdon Chris Langdon is offline
Off Roading with low airpressure Question
i do a fair amount of Rednecking. my Jeep is lifted and I have never aired down my tires before. I always thought this was primarily for the rock guys and i am mostly trails, creek crossings and a little mud now and then.
Would airing down help or hinder off camber driving? We have some precarious spots and i have felt a little on ease before. Just looking for some advise before i learn the hard way!!
Chris in North Ga
*Never forget 9/11
81 J-10 Honcho Flat-Bed,360ci built,AMC-20Detroit, Dana 44 ARB, Warn 9k , F&R bumpers rock slider Bars, 34" Super Swampers, spring over with 4" Superlift, original interior.
This was my Pa's Truck.
I love 4 Wheeling
Old 05-09-2010, 03:49 PM
This would probably get more answers in the offroad section...
46 cj2a
51 Willys p/u
'51 Willys Parkway Conversion
'74 CJ5
'75 J-20 Wrecker
'75 J-20 Cummins service bed
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Old 05-09-2010, 04:00 PM
Chief Gunner's Avatar
Chief Gunner Chief Gunner is offline
I would think that airing down would make you less stable on off camber situations. The benefit to airing down on the rocks is that your tires conform to the rocks aiding in traction. I would think in soft sand or snow, airing down would help out as well because your "footprint" would be bigger. However in off camber situations, your sidewalls can flex a little more and possibly give you a degree or more of lean. Just my thoughts.
The War Wagon: 1986 GW- SOA/SF on 33X12.50's, 360/727/NP228, CS 144 Alt, OBA
Wife's DD: 2012 Ford Focus SEL
My carbon foot print is bigger than your's.
WWW.SOCALULTIMATE4X4.COM
Old 05-09-2010, 04:05 PM
Good point, that would add stress to the bead and would pop off easier.
46 cj2a
51 Willys p/u
'74 CJ5
'75 J-20 Wrecker
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Old 05-09-2010, 04:41 PM
Blake Blake is offline
I air down because it makes the ride way smoother. I've been on some very, very off camber spots and never had a problem or wish I was at street pressure.
Old 05-09-2010, 05:40 PM
Lindel's Avatar
Lindel Lindel is offline
Perfesser of Jeepology
From all appearances, this SHOULD be one of the busier threads on the board, however, it would seem that most replies have gone elsewhere, and the post authors have gotten all mixed up as well.
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Old 05-09-2010, 05:58 PM
That could be true, but I think it also depends on your wheel tire combo. I am running a 33X12.5 tire on a 15X 8 wheel. I think this is a great combo cause I can air down and the tire still pushes against the wheel keeping it on the bead. My friend is running a 35X12.5 on a 15X7 wheel, and the tire doesn't sit flat, so airing down allows the tire to sit flat. If you are running a 12.5 wide tire on a 10 inch wide wheel, there would be a better chance of popping a bead. In all reality, it is a trial by error game. You have to find the air preassure that works for you with the tire/ wheel combo you have. Speaking of that, I wish I had beadlocks.
Old 05-09-2010, 07:44 PM
Locked and Loaded's Avatar
Locked and Loaded Locked and Loaded is offline
Airing down makes washboard roads Soooo much better.
Drink more water.
"Nothin' ain't worth nothin'.
But it's free"
Kris Kristofferson 1970
1981 J10, 258, T176, NP208
Old 05-09-2010, 07:55 PM
cocurtiss's Avatar
cocurtiss cocurtiss is offline
X2
1981 J20
soa/sf
36x12.5x16.5 Goodyear Military oz
no rust!
Status: Top end tore apart
Old 05-09-2010, 09:34 PM
802Hoop's Avatar
802Hoop 802Hoop is offline
I wheel similar conditions in Vermont, and I ALWAYS air down my tires... even for steep grades, and precarious locations. Similar to what was mentioned above, my tires are wide, and my wheels are rather narrow so I can air them down A LOT without any issues. With that said, you can still air them down if you have a 10" wide wheel, you just don't air them down to sub 10 psi, like I do. Next time you go out, try taking them down only 10 psi, then next time try 15, then 20, and so on. If you don't like the change in your off road handling characteristics, then run them full again. Some of it is preference, but I think you'll find a smoother ride will make you enjoy the drive much more.
Old 05-10-2010, 07:21 AM
bill3's Avatar
bill3 bill3 is offline
I do the same style of wheeling. I air down my 33x12.5x15 BFG A/T'S on 10" rims down to 20 PSI and they do GREAT. Now when I was running my 35x15.5x15 swampers on 14" rims, I never aired them down untill the tred wore down.
1981 J10 4X4 STEP SIDE
ENGINE: CHEVY 427
TRANNY: TURBO 400
T-CASE: NP208
FRONT END: DANA 44
REAR END: 10 BOLT
GEAR: 3.73/LOCKER
LIFT: ROUGH COUNTRY 3 or 4"
TIRE: BF GOODWRENCH 33X12.50X15
RIMS: STEEL
Old 05-10-2010, 09:05 AM
Headhoncho's Avatar
I wouldn't worry about that unless you have a narrow-trac with alot of lift and skinny tires. I air my 37's down to 12 (h2 rims) and my 38's down to 18 (16.5 rims) and they work great. I run alot in Jersey Pine Barren sand and Pa. rock and stump filled trails. Airing down really helps soften the ride on bumpy trails. Haven't felt threatened by off camber situations yet but we'll see what happens at ECI next month with my young padawan driver. Airing down is the main reason I installed on-board air.
JR
1966 mustang fastback
'07 Dodge Charger 3.5
Old 05-10-2010, 11:01 AM
I air down to 20 PSI on 33X12.5 right now. I tried airing down to 15 PSI, but the tires kept ruubbing the fenders too much. Once I open my fenders a little, I will be able to easily air down to 15 or even 10 PSI. the trick as some one mentioned earlier is to experiment a little. Find the air pressure that feel right for your driving style and terrian that you wheel in. This is one of theose personal preference issues.
Old 05-10-2010, 01:17 PM
dank idea's Avatar
dank idea dank idea is offline
I have yet to air down in my FSJ but, with my XJ w/31" tires i always aired down in mud and especially in the snow.
...does a fat dog have lips?
1982 Jeep Cherokee(FROGZILLA) w/I6,soa/sf,36/12.5/15 swamper tsl's, Lincoln locked rear
1991 XJ 4' lift and cut
2001 Mitsubish Montero Sport (wifes ride)
Old 05-10-2010, 01:50 PM
lost1's Avatar
lost1 lost1 is offline
I generally don't bother airing down unless I get stuck... at the first sign of trouble I'll air down and usually just pop right out of whatever hole I was about to dig for myself.
That said, I don't generally go many places that get really off-camber, and you can feel it more when you do find a hairy spot. Sand, mud, snow, I've had success airing down in all of them; with really wide tires the benefit might be less noticeable than with the ones I tend to run. (up to 33s in the past on an XJ) And remember, how much you can air down safely depends on how you've matched up rim/tire size. stockers on 15x10s can't reliably go as far as on a 15x8, for example. (don't laugh, I've seen it.)
Jeeps don't get stuck. People do.
Let the good times roll!
'83 Wagoneer«» 401/TF727/3:31 AMC20
Old 05-10-2010, 02:00 PM
orangecherokee's Avatar
air down, it helps. The problem is if you're not running beadlocked wheels (which I assume you aren't). You have to find the happy medium. Too low and you'll roll a bead. Too much and you're not getting the full benefit of the tire. Also, if you're running 16.5s don't try and air down much, it'll slip off in a heartbeat and you'll be spending the majority of the day reseating beads.
For snow and mud I've always heard 2 schools of thought. Air-downed tires give a bigger footprint and allow more tread contact which will allow the vehicle to "float" better (float being relative). Taller, skinnier tires are able to reach to the hard surface below and have better traction. I personally have never ran a tall skinny tire because I believe a larger contact patch is better. I run as little as 4psi in the rear and 7 up front. I also run beadlocks.
To sum it up, air down to 12-15 and let it fly
Old 05-10-2010, 02:41 PM
Serious Johnson's Avatar
33x9.5s on my narrow-track. Airing down does make things a bit tippier on sidehills, and around here that can result in a thousand vertical foot tumble. For that sort of work, I like to have the tires at street pressure (40 psi) and the shocks on full hard. I don't air down for snow or mud (except the red clay and cement snow back in the southeast), but go down to 20-25 psi for boulders, and as low as 12 psi for dry sand.
S.J.
"Carpe Mañana".
'83 Wagoneer
Old 05-11-2010, 07:33 PM
I like the idea of experimenting. How about a few suggestions for Bead lockers?
this jeep spends 90% offroad. That is such a cool statement to make and make honestly.
this thread has been very informative.
Chris in North Ga
*Never forget 9/11
I love 4 Wheeling
Old 05-11-2010, 08:17 PM
68glad's Avatar
68glad 68glad is offline
keep in mind also the tire size compared to rim width. The contact patch of a wide tire on a narrow wheel will grow in length & very little in width.
68 gladiator- 455/400/20 r.i.p.
78 wagoneer- 401, drw60, drw70, 203/205, 38's, oba, obw, hydroboost, dual p/s pump, bla bla bla
Old 05-12-2010, 12:05 AM
warrpath4x4's Avatar
warrpath4x4 warrpath4x4 is offline
Let's see beadlocks beadlocks beadlocks? Lol
There is the weld on beadlocks which will only lock your outer bead (unless running a huge wheels and welding a set on the back also).
Internal beadlocks such as staun or innerairlocks which will lock both beads and will look stock minus the second valve stem on each wheel.
H1 wheels which usually need to be recenterd, will lock both beads with the insert, but usually are very hard to balance.
Then there's the TEK screws, basicly just using self tapping screws and screwing them into the wheel surface into the tire bead or behind it. I've seen it done on both beads. Its also a old skool hot rod tip.
AMSOIL DEALER
North East Oregon 4Wheelers
Travel Trailer towing question... The_Turd General FSJ Discussion 13 06-05-2008 09:16 AM
4 inch lift install question and razor question gmarblestone General FSJ Tech 14 03-26-2007 10:22 AM
2100 Question Deacon General FSJ Tech 15 03-14-2007 01:12 PM
Fuel Gauge Question srobertsfsj General FSJ Tech 7 07-05-2006 08:08 PM
thermostat tech question roadgrime General FSJ Tech 11 06-12-2004 04:30 PM
