Old 11-21-2009, 01:12 PM
jlchilcot's Avatar
jlchilcot jlchilcot is offline
old meyer plow info
I just got a plow off a guy here on the site. I would like some pics/documention of this setup. Its the old meyer setup with the belt driven pump. Mounting the plow to the truck won't be a problem but id like to see exactly where the pump its supposed to mount on the engine and where the hydraulic block is supoosed to mount. im sure someone here has some pics or info.
75 J-20 360 T-18
77 Cherokee Chief 401 QT
80 CJ-7
2000 Ford Explorer Eddie Bauer 5.0
2000 Ford F-250 Powerstroke
See my Jeeps here
http://picasaweb.google.com/jchilcot
Old 11-21-2009, 05:28 PM
mrtazwrench's Avatar
mrtazwrench mrtazwrench is offline
I have a simmilar setup, it was from a dodge and made to fit Jeep, so I'm not sure how the made for Jeep stuff fits. My pump is actually an old Jeep P/S pump with bits from the origional dodge pump on it, and is mounted under the power steering pump, the res is cut into the driver's inner fender, and the valve block is near where the ignition module mounts, I moved the module to mount it, and the control rods go through into the cab. I keep the control rods away from the door a bit as the first truck this was in the rods interfered with the window crank and the door neede to be opened to roll the window down.
Chad
"Let's see that Red Blue Green **** sucker build one of these without duct taping it together!"
88Wag
87J20 Member, FSJ Prissy Restoration Association
83Cherokee WT
82J20
Parts vehicles: 1.5 Wags, 3.5 J20's, 1 J10 1 J300
Old 11-21-2009, 05:45 PM
Theres a thread in the offroad forum that is discussing dual P/S pump options. I know they would love to see pics of your bracketry...
http://www.ifsja.org/forums/vb/showthread.php?t=104644
46 cj2a
51 Willys p/u
'51 Willys Parkway Conversion
'74 CJ5
'75 J-20 Wrecker
'75 J-20 Cummins service bed
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Old 11-21-2009, 06:09 PM
I posted there, been too busy to get pics up, it's not pretty, something that someone else fabed, then I adjusted a little, I had to use a piece of reay rod in one spot instead of a bolt to have it threaded far enough.
Chad
88Wag
83Cherokee WT
82J20
Old 11-21-2009, 07:13 PM
Tornado230's Avatar
There is a parts list and an illustration of the installation and instructions in the special equipment service manual (the one with the green cover).
I have it in the garage at this time.
I can scan the pages and e-mail if you will get me your e-mail address.
Dave
Old 11-21-2009, 07:33 PM
Dave
I would like to get a look at how it's really supose to go also.
Chad
88Wag
83Cherokee WT
82J20
Old 11-21-2009, 07:46 PM
I got the Willys....
My Special Equipment manual shows the pump being mounted on the passangers side of the Jeep, right above the alternator )for V8's), and the valve block on the drivers inner fender.
The mounting brackets where just various peices of bent flat stock with slotted holes in them.
1971 Gladiator
Old 11-22-2009, 05:24 AM
jlchilcot's Avatar
Id like to see what you have. jchilcot@gmail.com
Thanks
75 J-20 360 T-18
80 CJ-7
See my Jeeps here
Old 11-23-2009, 08:58 AM
Tornado230's Avatar
Information sent.
Check your e-mail.
Dave
Old 11-28-2009, 12:47 PM
jlchilcot's Avatar
I got the info Thanks. However mine is a different setup than that. I have one of the universal pump/resovoir units. Any one else have one of these? The pump and resovior are one unit.
75 J-20 360 T-18
80 CJ-7
See my Jeeps here
