Old 11-26-2017, 10:11 AM
BigDctd's Avatar
BigDctd BigDctd is offline
Noob!
Lightbulb MTNWAG. 86GW
Hello! Poster here a few times in the past. have received great info and hope too in the future.
Last winter I took my bone stock wagoneer and added a SOA/shackle flip, custom bumpers, custom roof rack and EFI. Drove it around the ranch a little bit, playing with the tuning and working bugs out. Then got my hands on a drivetrain from a 93 cummins. And that's when the wheels started turning!
Plan
2inch body
6bt, 5 speed, 60/70s (turbo,IP upgrades,injectors, springs. Shooting for 300+ hp, 8-9 ft lbs torque)
Plated and boxed frame
New bumpers
3-link/Coilover front
Stock springs in rear, outboarded shocks, and a custom cantilever airbag overloads.
New seats (buckets?)
Custom gauge cluster
The project has been going a while, I'll do my best to update as I go.
So far I have original drivetrain pulled, 2 inch body lift done (fixed the one rotted mount, rear left mount), 3/16 plated inside and outside of boxed section (will box rest of the C- section). Coil buckets measured and tacked in place, and motor sitting in the hole!
Stock wag.
Last winters transformation.
Tear Down.
The rest.
DWK
86 GW
Old 11-26-2017, 12:15 PM
Kaiserjeeps's Avatar
That is a cool build. I will be following for sure. On your 93 12 valve, check your fan bearing support very carefully for cracks. They have been known to fail ruining everything in front of the motor. I recently helped a guy get one made at a machine shop. They are extremely hard to come by and we searched every dark corner of the internet. Second gen fan supports are available all day long and won't work without changing everything over. I tried to buy his 93 dodge for almost a year. But ended up helping him get it fixed. And if you don't subscribe to the Diesel registry from Geno's garage, you should. I signed up when I thought I was going to get a 12 valve for my CUCV. I changed my mind but the magazines keep coming. It is truly good reading for first, second and third Gen trucks and their motors.
Great build and looking forward to more.
Am I done yet?
Holy Moly, I am done.....
1969 1414X Wag,
71 project J truck FOR SALE
1970 Wagoneer Not Sadie
1983 FJ60 wagon
CJ-5's
Old 11-26-2017, 06:24 PM
bkilby's Avatar
bkilby bkilby is offline
Nice project! Can't wait to see more progress.
Old 11-28-2017, 10:10 PM
BigDctd's Avatar
Noob!
Can't say I have heard of it the issue with the fan bearing housing. Have heard of the Killer Dowel pin. Plan on fixing that. But I will definitely look into that, thank you!
Motor mounts built and tacked in today.
DWK
86 GW
Old 11-29-2017, 06:47 PM
BigDctd's Avatar
Noob!
Transfer case in, and started the cross member. Trying to keep it tucked up tight as possible.
DWK
86 GW
Old 12-01-2017, 07:03 PM
BigDctd's Avatar
Noob!
Transmission crossmember in and halfway bolted.
There is tubing connecting the two. The mounts hide it in the pictures.
DWK
86 GW
Old 12-02-2017, 08:16 AM
Full Size Jeeper's Avatar
Very nice work. What ever (it) is, you have it.
1978 Wagoneer
Mods:
Old 12-03-2017, 01:47 PM
BigDctd's Avatar
Noob!
Getting the 3-link dialed in.
DWK
86 GW
Old 12-05-2017, 05:18 PM
BigDctd's Avatar
Noob!
Rear axle and leafs are out. AMC 20 looks scary small compared to the 70. New springs should show up on UPS tonight.
DWK
86 GW
Old 01-04-2018, 09:44 AM
CameraFinn's Avatar
CameraFinn CameraFinn is offline
Great looking build so far. Fun to see somebody else using that excel sheet for three links. That's what I used too when I made my front 5 link. I got my numbers dialed in, and then went out to the truck to weld everything on, I just had to get as close as I could -- I couldn't get mine perfect.
We've even got the same adjustable upper link and panhard mounts. Be careful where you put your frame side panhard mount though. I didn't have much choice with mine, but now on a full suspension cycle it about hits the tie-rod.
Great work on the crossmember too.
Finn
You know it's a good morning when the gas gauge works for the whole drive.
1970.5 Gladiator J-4800 Camper Special Custom Cab - 55,000 Miles (Under Reconstruction)
1967 Jeepster Convertible - 8071 Deluxe - 65,000 Miles
Old 01-04-2018, 03:29 PM
Thanks for posting all the pics and info! Looks like you are building a solid rig. I think I speak for all of us when I say we are really looking forward to seeing this truck get back on the road! AWESOME!
Old 04-12-2018, 09:07 PM
CameraFinn's Avatar
Updates?
Hey, I was just wondering how your build was going. What's your finished suspension looking like?
Finn
Old 04-13-2018, 12:17 AM
Ditto, I just enjoyed the heck out of looking at all the pictures again.
Am I done yet?
1969 1414X Wag,
1983 FJ60 wagon
CJ-5's
86GW 360 stalls after put in gear.... caban General FSJ Tech 3 05-10-2005 07:56 AM
chevy leaf springs on 86GW 86 BigWag Off-Road FSJ Tech 7 01-02-2005 12:04 PM
86gw rear axle bearings and wheel studs ARJeepman General FSJ Tech 2 05-30-2002 01:52 AM
86GW seat belts and seat covers need replace 8689gwagons General FSJ Tech 0 03-22-2002 01:17 AM
Engine swap problem--'88 GW360 into an '86GW 8689gwagons General FSJ Tech 5 03-21-2002 02:24 PM
