Old 09-01-2020, 08:51 AM
LHopper's Avatar
LHopper LHopper is offline
Problem after intake gasket replacement
I finally bit the bullet and had a shop do my intake gasket shield replacement. Now I have low oil pressure or at times drops to zero, and the heating issue which is also a new problem with the intake manifold shield gasket be installed wrong?
78cherokee360 4b carb. auto tob.400q/t D44 BFG 33`s w/2.5 lift w/added lowrange,TFI upgrade, and cat free
Old 09-06-2020, 08:38 AM
LHopper's Avatar
Oil pan next
I’ll leave a the intake gasket alone and pull the oil pan and check the strainer on the pick up..
Old 09-06-2020, 08:16 PM
lkmarsh's Avatar
lkmarsh lkmarsh is offline
Sealer clogging the pickup is my guess.
Lyle
68 Chevelle wagon 350/BWT50
68 Impala wagon 327/400
04 Impala LS - Wife's DD
73 Wagoneer parts donor
Old 09-07-2020, 12:44 PM
LHopper's Avatar
That is just what I was thinking Time for a new pan gasket and a check on the pickup.
Old 09-07-2020, 01:36 PM
LHopper's Avatar
After looking at my spare pick up to the screen is a lot smaller than I thought that will be my next project.
Thanks
Old 09-07-2020, 03:51 PM
Probably just the oil pressure sender lead. Check the wires and connection at the sender.
QT Problem After Chain Replacement Cliff General FSJ Tech 7 08-17-2020 04:11 PM
258 oil pan gasket replacement Benandjoesdad General FSJ Discussion 3 11-07-2017 09:39 AM
Clearance problem: 258 intake and 4.0 exhaust! Remedies? backroadin' General FSJ Tech 15 10-20-2006 10:31 PM
intake manifold gasket update Torque General FSJ Tech 2 09-09-2002 02:41 AM
intake manifold gasket Torque General FSJ Tech 15 09-08-2002 09:00 PM
