Old 04-21-2020, 10:07 AM
SnowShoe's Avatar
SnowShoe SnowShoe is offline
Question power source
What do you'al use for a bench power source to test electrical components ie: wiper motor, tailgate window motor. etc.
Old 04-21-2020, 10:11 AM
Weird, it created 4 different threads for you. I just use a couple alligator clip type leads, clip them to the posts for the mechanisms, then have my 12V battery close enough to touch the other ends directly to the battery posts. Works great.
Edit: Suddenly I see only this thread. Hmm...
Old 04-21-2020, 10:16 AM
SnowShoe's Avatar
Lightbulb
I fixed the extra posts.
I would use a battery if I had one but, right now I'm just testing systems before I install them in my restoration.
Is a battery my only solution?
Old 04-21-2020, 11:25 AM
Full Size Jeeper's Avatar
I have used my twenty year old battery charger to test run 12 volt motors, but not sure if this could damage the charger or not. It has worked for me over the years.
1978 Wagoneer
Mods:
Old 04-21-2020, 10:11 PM
lkmarsh's Avatar
lkmarsh lkmarsh is offline
Some things, like starters, you have to use a battery. Most other things
you can use an old battery charger. My newer, electronic one wont work.
I also have a small 12v bench supply from Radio shack for lights and
switches.
Lyle
68 Chevelle wagon 350/BWT50
68 Impala wagon 327/400
04 Impala LS - Wife's DD
73 Wagoneer parts donor
Old 04-22-2020, 03:50 AM
SnowShoe's Avatar
Lightbulb
switches.
I tried using my digital battery charger and it no work'ee Some of the motors
like to see 20-30 amps. So looks like I need to use a car battery to test with.
Old 04-22-2020, 03:51 AM
SnowShoe's Avatar
Lightbulb power sourse
switches.
Old 04-22-2020, 08:06 AM
A battery borrowed from another vehicle is the easiest.
You can buy a brand new smallish one from walmart for ~$40.
An old 14v drill battery works well too, I carry one on JY trips when grabbing electrical parts to test before buying.
Old 04-22-2020, 02:51 PM
SnowShoe's Avatar
Thumbs up
Thanks Tony Great ideas
Power steering line O-rings, source? JeepsAndGuns General FSJ Tech 13 08-30-2020 07:58 PM
Power Valve kevinator General FSJ Tech 14 10-15-2011 07:17 PM
More throttle...less power Johnny&Midge General FSJ Tech 8 12-20-2008 07:36 PM
Looking for a 12 v power source Paul General FSJ Tech 2 02-05-2005 01:23 PM
hooked up battery terminals wrong-now just clicking... ctjeepman General FSJ Tech 10 09-18-2004 10:23 PM
