Old 04-03-2020, 05:12 PM
legion77's Avatar
legion77 legion77 is offline
Switching from 6 lug to 5 lug
I have a 1977 Cherokee and I would like to change from the 6 lug to 5 lug. Is that a difficult to do? Any help would be appreciated.
Old 04-03-2020, 06:17 PM
front axle is easy. ford stuff. rear axle would need custom shafts or just a 5 lug rear axle swapped in.
Old 04-04-2020, 07:48 AM
lkmarsh's Avatar
lkmarsh lkmarsh is offline
Ok, I'll bite: why would you want to change from 6 to 5 lugs?
Most swaps go the other way. You have a particular rim in mind?
Lyle
68 Chevelle wagon 350/BWT50
68 Impala wagon 327/400
04 Impala LS - Wife's DD
73 Wagoneer parts donor
Old 04-04-2020, 09:20 AM
If you have good tires on 5 lug wheels, sell the wheels and buy 6 lug wheels. Unless you are very lucky, you'll spend a lot of time searching for a 5-lug rear axle, and it will very likely need to be re-geared to your current ratio. And parts for the front axle won't be free.
Old 05-14-2020, 10:14 AM
Could go a matching Ford axle pair.
88 Grand Wagoneer switching to 4x4 HobokenWagoneer General FSJ Discussion 11 07-08-2015 01:44 PM
Manually switching over to 2wd? clabelle General FSJ Tech 2 07-27-2010 12:49 PM
Opinions: switching from 33x12.5 to 33x10.5 MTs N2Jeeps Off-Road FSJ Tech 6 07-10-2009 09:32 PM
Switching from 5/8" to 9/16" lug studs?? Dmntxn77 General FSJ Tech 4 10-01-2007 10:28 PM
(corrections) switching from driver side to passenger side trcooperone General FSJ Tech 11 05-02-2007 11:05 PM
