Old 11-11-2009, 12:21 PM
Tourettes's Avatar
Tourettes Tourettes is offline
Front driveshaft replacement
The guy at my local driveshaft shop says my front driveshaft is shot.
Will a front driveshaft from an AMC Eagle fit my Wagoneer?
Are there other driveshafts that will work from different vehicles?
Tourettes 1978 Wagoneer
360-727-228 - MSD 6a - TFI - MSD 8.5mm - 880CCA Diehard Plat - 31x10.5x15 - LEDs in every socket
Old 11-11-2009, 12:28 PM
Tornado230's Avatar
The front drive shafts are different.
Find one from the same year and engine/transmission/transfer combination, or have yours repaired.
Old 11-11-2009, 12:46 PM
j20brett's Avatar
j20brett j20brett is offline
360 AMC
You should ask what exactly is shot. If its just the u joints then they are cheap and easy to replace.
Build Thread
Fight Crime...Shoot Back.
ΜΟΛΩΝ ΛΑΒΕ
Old 11-11-2009, 02:28 PM
FSJ Guy FSJ Guy is offline
You can get replacement parts for the double cardan, including the centering pin (ball thingee) and the outer casing of the CV joint, commonly called an H.
Ethan Brady
www.bigscaryjeep.com
Old 11-16-2009, 02:23 AM
Tourettes's Avatar
Thank,
He says the driveshaft is shot due to the damage to center pin where the "ball thingy" goes. For everything else replacement parts are available.
Is he telling the truth?
Old 11-16-2009, 09:25 AM
Bummer. That's about the only thing that ISN'T replaceable without going to a custom driveshaft.
Time to hit the boneyards.
Ethan Brady
Old 11-16-2009, 01:11 PM
flatbackdragon's Avatar
flatbackdragon flatbackdragon is offline
you CAN find the part at www.napaonline.com
browse the catalog-drive line-enter your vehicle info-ujoints and related stuff-on page 3 or 4 on the bottom you will see 'double cardan (CV) H yoke, item # PUJ647, price is 63.99
the other parts are available there too, centering yoke (for use of 'ball thingy) #PUJ607
if there is a NAPA in your area, call them to see if they have/can order it IF that is the problem.
if where the ujoints fit into the shaft are rounded out due to joints worn out, then a whole shaft would be needed but otherwise parts can be had.
A driveshaft co. should know that, have them SHOW you what is bad so you know for sure what you'd need.
"There's an inner idiot in us just waiting to climb out and romp about in unabashed stupidity, but most people retain just enough wit to keep the idiot bottled up."
Gary Harmon-writer for Grand Junction Daily Sentinel (newspaper)
Phil (or Flip, Dragon)
Draco-79 Cherokee 360/QT-4" lift-pretty much stock and trying to fall apart
