Old 06-15-2009, 11:30 PM
Muni Muni is offline
Welded front
I just finished lifting my 84 grand wagoneer not to long ago and am wheeling it a lot more. The ground clearance really helps.
I'm going to weld the rear diff and I'm thinking of welding the front as well.
Normally I wouldn't consider welding the front but my 84 has the Vacuum disconnect front axle so I will be able to lock or unlock the front end from the Cab correct? So that way the welded diff won't affect my normal drive ability and it will give me a locked up front end when I go wheeling. I have power steering so turning it shouldn't be to hard I would guess and rocks where I go are a minimum. Mostly loose dirt and mud.
I'm Saving up for lockers and 4.56 gears. Still running the stock 3.31s for now. But i think the welded diffs will last me a while so I can save up.
Any flaws in my thoughts?
Old 06-16-2009, 03:40 AM
pineymike's Avatar
pineymike pineymike is offline
Unless you install lock out hubs you'll still have half of your drive train turning,If you don't drive on the street much it won't be too bad but,I wouldn't do it on a DD with out lockouts.I do have welded front on my offroad comanche it works good,no problem turning&I like it!
Old 06-17-2009, 09:45 AM
L98Waggy's Avatar
L98Waggy L98Waggy is offline
Member (huhuhuh...member)
On a baby jeep it would be ok but FSJs dont turn great to start with. Plus,the extra weight wont help matters. I rode in a buddys 79 cher. with a welded diff on its first trip wheelin and he put it on the trailer and we wheeled mine. I would get a spare carrier and pick up an Aussie locker and never look back. You will be much happier in the end.
God grant me the serenity to accept the impossible trails I cannot crawl,courage to crawl the twisted trails I can and the wisdom to keep tire side down.
Old 06-17-2009, 10:02 AM
Chevelleguy's Avatar
Also, unless you modify the vacuum system, inorder to disconnect the front axle, you have to take it out of Low the out of 4WD.
Old 06-17-2009, 10:44 AM
jeepsr4ever's Avatar
www.Bulltear.com Chief
I dont like welded fronts personally. If you were just mudding I would say go for it but you really loose your steering offroad.
AMC/Jeep Forum
Old 06-17-2009, 11:59 AM
Headhoncho's Avatar
x2. I noticed a huge difference in turning effort after I installed an Aussie locker in the front of my truck. I wouldn't want a welded front diff unless it was for playing in mud either.
JR
1966 mustang fastback
'07 Dodge Charger 3.5
Old 06-17-2009, 01:04 PM
I think I'm still gonna weld it and put manual locking hubs on it and see how it works out. If getting an aussie were an option I'd have done it already. I'm looking for an inexpensive fix until I can get some cash saved up to put lockers at both ends and new gears. I'm thinking 4.56's.
Old 06-17-2009, 01:52 PM
DAHoyle's Avatar
DAHoyle DAHoyle is offline
The vacuum disconnect only disconnects one shaft. The other will still be tied to your driveshaft, unless you have locking hubs.
All things considered, you can probably get away with it, but I wouldn't count on it living very long, if you have to disconnect the front axle every time you get bound up and need to turn.
If you can't afford an Aussie right now, you can't afford to be replacing any broken parts either. Best to enjoy it as it is, till you can afford what you want.
67 M715
Old 06-17-2009, 01:53 PM
L98Waggy's Avatar
Not to sound negative but getting a 250 dollar aussie will make you feel like you have 5.38 gears off road. Spend the money on the boxlocker first then think about gears after you wheel it. Especially if you want to drive it on the street too. I was gonna put 5.13 in mine to replace the 4.10 till I decided to put in a locker in the front 44. I found out the skinny pedal actually made a difference! The same trail I had to slide down backwards a month before.....I got to see the top of. If you do weld it,be sure not to get slag on the axle shaft or that will be another expense. Again do what you can afford but...... (IMHO)a cheap locker is gonna do you better than a low geared rig you cant steer offroad or drive onroad.
Old 06-17-2009, 02:10 PM
I guess I may wait on the front axle then. Dunno now.
And I have 3.31 gears in my rig now and this is gonna see minimal street use. Not building a big scary trailered rig but something very capable off road which i can drive to the trails. The trails are 20 miles away.
