Old 07-20-2022, 11:17 AM
cu4whln's Avatar
cu4whln cu4whln is offline
Will a 33x10.50 Spare fit ?
I am running 33x12.50s
As I prepare for a long road trip, I want a spare available "just in case"
Can I fit a BFG KO2 33x10.50 under the rear cargo floor?
Where the original tire would have been.
On a stock chrome junkyard wheel btw.
Not getting a clear result on search function.
Looking for real world experience before I buy a tire.
TIA !!
1977 "401" 'Da Chief
1979 Chero: "Madness" [Sold]
2001 XJ : Driver - 2016 JK 2 door
Round 2- LT Swap: 'Da Chief:
"Madness" build here:
Old 07-20-2022, 12:28 PM
I doubt it, not just from a height perspective, but mostly from a width perspective. I had to adjust the hinge to its lowest point just to get a stock 235 tire to fit in there and allow me to get the arm bolted back up near the rear bumper.
A 10.5" inch thick tire is way wider than a stocker, so unless you made a custom hinge that hangs much lower that allows you to get the entire arm bolted back up, I'd say your best bet is to throw the combo in the cargo area or on the rooftop.
--Rob--
My build thread:
My Howell TBI Install How-To:
Old 07-20-2022, 05:28 PM
Cliff's Avatar
Cliff Cliff is offline
That much weight on the roof always made me nervous. If you have a hitch, make up a spare holder that fits into the hitch. In the way of the tailgate but it can be moved. Just an idea.
Cliff Danley
1977 Cherokee S
Old 07-20-2022, 05:33 PM
asphaltrockdweller's Avatar
Maybe get a hold of Bob over on FSJN, and see if he has any of these available?
https://www.fsjnetwork.com/forum/vie...hp?f=34&t=5620
Old 07-20-2022, 06:49 PM
Curly5759's Avatar
Curly5759 Curly5759 is offline
I replied on your FB post, but I'll add it here as well. My77 Cherokee WT had 33x10.5 as a spare. It fit, the previous owner had modified the bracket to fit by extending the pivot end and adding a longer bolt. I found that I could not remove the spare without jacking up the Jeep, not enough ground clearance. With a flat, it obviously would have been worse. My fix was to have Bob make me a Swing away spare tire bumper.
77 Cherokee S 360/TH400/QT
Old 07-20-2022, 10:57 PM
cu4whln's Avatar
[quote=asphaltrockdweller]Maybe get a hold of Bob over on FSJN, and see if he has any of these available?
Ha ha!
I have one of those.. I took it OUT!
Welded up the holes when I painted it.
I need the space for overlanding stuff.
So, it looks like a "NO" on fitting this size spare under there.
I always carry a plug kit, so maybe I'll have to wing it without a spare.
Or, get a small tire spare to just get off the road.
Old 07-21-2022, 03:42 AM
Heep-J4000's Avatar
Maybe you have a look for a small 16 inch wheel/tire ,so it fits under your Jeep and can be removed without to much hassle And also have a diameter that is the same or close to the 33x10.50 tires.
Well that is what I would do and did with a spare wheel/tire on my j4000
Former vehicles:
Old 07-21-2022, 08:41 AM
It will fit under, but the stock tire carrier bracket isn't friendly for removal/install.
Could be modified but best solution would be to mount a newer style winch type mount to the underside of floor like from a ford ranger or similar.
Old 07-21-2022, 10:49 PM
cu4whln's Avatar
I have given this some thought!
Is the Ranger unit a good donor?
I figure I could weld a brace in, and then set up a tire winch. Maybe.
BUT - for now, I am just trying to get it back together.
It's killing me to not have this thing driving yet.
Old 07-23-2022, 07:13 AM
Heep-J4000's Avatar
Dodge Ram trucks have this same winch system for the spare wheel.
I'm going to use this on my 73' j4000 with utility bed.
Made a extra support bracket on the underside of the bed for bolting on the spare wheel winch system.
Former vehicles:
Old 07-23-2022, 10:02 AM
You can modify the stock bracket to work.
Old 07-23-2022, 12:43 PM
My '98 Dodge has one. Driving along the freeway once I feel a thump. Look in the mirror to see what I hit and see a tire rolling. It only took a moment to realize it was mine since I didn't see it ahead of me before I felt it.
Moral is you need to check these cable lifters once in a while. Planned to put something else also but never got to it yet. Coulda caused an accident.
Old 08-01-2022, 10:28 AM
I fit a 285/75R16 (about 32.75" diameter) in my spare tire holder. I had to really cram that puppy up there. I would think you could jam a 33 in there but it will suck.
I even wrote a post on it. Looks like some other folks have fit 33s in theirs. my issue was tread width more that diameter but the diameter is tough too.
http://www.ifsja.org/forums/vb/showthread.php?t=187315
(looks like my pics stopped showing )
Old 08-04-2022, 09:17 AM
I did the Dodge tire crane and love it. To solve the droop, I run a rachet strap from side to side as a safety strap. The J20 has had the same spare under it for 3 years.
43 cj2a
51 Willys p/u
'51 Willys Parkway Conversion
'74 CJ5
'75 J-20 Wrecker
'75 J-20 Cummins service bed
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Stock Spare Tire Storage svining General FSJ Tech 3 02-27-2012 05:02 PM
Spare tire advice Dr. Marneaus General FSJ Discussion 15 01-20-2012 09:37 PM
the spare parts box and emergency/first aid kit in your rig what do you keep in them? Wagoneerlover General FSJ Discussion 18 11-12-2008 07:48 AM
16.5" Tires for spare underneath Gladiator red mistress General FSJ Discussion 2 06-21-2008 07:40 PM
33x12.50 spare into the stock spare tire area, with pics phatmax95 General FSJ Discussion 29 05-21-2007 09:18 AM
