Old 01-15-2014, 11:48 AM
82jten's Avatar
82jten 82jten is offline
Bumper Question
Hey I found a winch bumper near me for $250, however it's for an early bronco, I was curious to know if anyone has run an early Bronco bumper on their rig, and how much work was it to make it fit?
Just
Empty
Every
Pocket
1982 J10
AMC 258- HEI Ignition, Clifford intake, Edlebrock 500cfm 4 barrel carb, mild cam
4 speed, Dana 44 front, AMC HD20 rear
31x10.5x15 m/t's
****** _,o000o
_____I_l,\____\,__
l_/--\__l__l----0lllllll0
_(o)_)__(o)_)--o-)_)___
Old 01-15-2014, 02:51 PM
goldhammer's Avatar
Used the center section from a big Bronco (93/94) from the Warn grille guard mount. Put my mount plates that I fabbed on the outside of the frame rails and to the inside of the mount plate. I used 1/4 inch for my mount plates, cut around the spring hanger rivets and built that area up and covered them.
Fabbed up my outer ends out of .120 flat and built in mounts for fog/driving combo lights. Grille guard is a cut down factory piece.
Not real good pic, but the avatar pic shows it. This is on my '81.
Art
ASE Master Collision Tech
3 piece front bumper install question Luntec General FSJ Tech 3 04-21-2008 03:18 PM
Bumper fab tips needed johnwaynejeep2 Off-Road FSJ Tech 26 01-08-2007 08:46 PM
Bumper question Paul General FSJ Tech 1 08-25-2004 05:34 PM
Post '78 one piece frt bumper question Elliott General FSJ Tech 3 05-07-2004 12:47 PM
Custom front bumper mounting question 90wag General FSJ Tech 7 04-06-2002 01:22 PM
