Old 09-28-2008, 02:49 PM
Curious - why is a 304 flexplate different from a 360?
Just wondering - I know that all the AMC V8s are externally balanced with unique flexplates, flywheels, balancers, etc. etc.
I can see why the 401 would be different from the 360 (different crank), but I understood that the 304 and 360 cranks are the same. I've also seen claims that the 304 and 360 cast factory flywheels are the same except (maybe) for the drilled balance holes.
Which is it, and if the 304 and 360 cranks are the same, what part of the rotating assembly is different enough to make the balance different between the two engines? Did the factory use the same flywheel casting for the 304 and 360 and machine them differently? If so, how to tell the flywheels apart after they have been separated from the engines?
Old 09-28-2008, 03:11 PM
eyotajeeper eyotajeeper is offline
Here is a photo of a 360 flexplate on the left and a 304 on the right.
The difference being in the bottom section cutout.
http://i420.photobucket.com/albums/p...eper/038-1.jpg
Old 09-28-2008, 03:54 PM
Lindel's Avatar
Lindel Lindel is offline
Perfesser of Jeepology
The difference would be the piston size. The bore on the 360 is bigger than the 304. That's also the reason the heads are different as well.
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Old 09-28-2008, 04:51 PM
rowdy235 rowdy235 is offline
I am facing this issue right now as the newly rebuilt 304 included with my jeep (with blown 360) doesn't have the flexplate. Oddly enough the f.p. for the 360 is cheaper than the one for the 304. Not fair IMO.
