Old 10-18-2007, 12:20 AM
68_Gladiator's Avatar
68_Gladiator 68_Gladiator is offline
hell creek
so i was told that hell creek had a suspension lift in both 4 and 6 inch for a 68 gladiator but according to the site its only offered in 4 inch for 63-69 and the 6 inch lift being only available for 74-75 and 76-87 so is it true that for my application (being a 68 gladiator) i only have a 4 inch lift option? if so how can i pull 6 inches of lift on it?
"Go Brow or go home"
1973 J2000
Old 10-18-2007, 04:21 AM
jeeping1974's Avatar
i'm not sure if they are working on a 6" lift for your rig but you can add 2" blocks to the rear and have a local spring company make up a pair of 6" leaf springs for the front.
03 GMC 2500HD - DD/toy hauler
06 Street Glide - Cruiser
Old 10-18-2007, 07:32 AM
Stuka's Avatar
Stuka Stuka is offline
Call hellcreek, they will most likely make you up a set of springs.
Old 10-18-2007, 09:45 AM
jepj2000's Avatar
jepj2000 jepj2000 is offline
From what I have seen, the production springs for the early Jtrucks comes out closer to a 6" lift than a 4".
What are you planning on doing in this truck, because the axles are not the strongest and if you put 35's of bigger and do hard wheeling you may be going through a lot axle parts.
Rankin
1972 J2000: 304, T18, Dana 20, Dana 44s w/ 4.09s, Rear Detroit, 7.50-16s
1977 J10: 401, TH400, Quadratrac, partime kit, Dana 60's , 4.10s, welded rear, RS44044s SOA, 63" Springs inboarded, 36" Goodyear RT IIs
Old 10-18-2007, 01:26 PM
Dirtball's Avatar
Dirtball Dirtball is offline
Tom is on here as Hellcreek... send him a PM and he'll get back to you very quickly. He often has specials on Ebay... search for fsj lifts or jeep lifts.
Paul
1979 Cherokee N/T
360/TH400/Qtrac/D44s/rear Lock-right
6 inch Hell Creek all spring lift
34x10.50 Super Swamper LTBs
http://i54.photobucket.com/albums/g1...t/100_1394.jpg
http://i54.photobucket.com/albums/g1...t/100_1390.jpg
http://i54.photobucket.com/albums/g1...100_1387-2.jpg
