Old 01-14-2007, 05:43 PM
AlsChopShop's Avatar
major oil leak...
developed a hefty oil leak between the motor and bellhousing of the trans today just running down the street and back.
what would be the culprit and how would i go about fixing it?
Al
Old 01-14-2007, 05:47 PM
Crazy_Jeepman's Avatar
Sloppy Shifter
Well sounds like a rear main seal. Though it could be from the back of the intake manifold, or Valve Covers, you would need to nail it down as to where it is actually coming from.
Old 01-14-2007, 05:56 PM
i'm 90% sure its not the valve covers or intake.
Al
Old 01-14-2007, 09:01 PM
jsinajeep's Avatar
Well first, is it engine oil or trans oil. If you don't know do the tast test. Red or burn smell = trans, and brown to black = engine. [most of the time]
Old 01-14-2007, 10:25 PM
Yup AMC's patented Rust Proofing and Chassis Lubrication Port...aka rear main seal.
Might take a close look at the valve cover gaskets too. They can leak from the rear and make it look like a rear main seal leak.
Old 01-14-2007, 10:36 PM
wangoneer's Avatar
wangoneer wangoneer is offline
I'm not fixing my rear main until winters over! It's the only reason my wag has lasted so long in salty Nebraska. With any luck, it will blow again by next winter!
Brian
81 Wagoneer
360 w/Holley Truck Avenger carb, 727 trans, 208 T-case, D44 open front diff, AMC20 w/Aussie locker out back
4" BJ's lift, "slightly" trimmed fenders, 34" LTB's, dewooded
Old 01-15-2007, 01:30 PM
i waited for the motor to cool then ran my hand behind each valve cover and around the back of the intake... just grime, no oil. so it has to be the rear main. and no, it isn't trans fluid.
anyone have the writeup on how to change it? or should i just drop in the SBC a little earlier than planned?
i'd drive the darn thing but it's smokin real bad and with my luck i'd catch it on fire.
Al
Old 01-15-2007, 01:48 PM
FSJ Thing's Avatar
FSJ Thing FSJ Thing is offline
Propane Protagonist
Might be the cam plug too. If it's a leak that's gradually gotten worse over time, it's probably the rear main. If it's all the sudden puking oil out of the back of the motor it's likely the cam plug, which is bad, because it's one less thing to keep your cam from walking...
I hope it's just the rear main. That's easier to fix anyways.
The Cherowagladabego Project. Updates coming as soon as I do something update worthy.
Old 01-15-2007, 01:50 PM
scantar's Avatar
scantar scantar is offline
Al
Al,
There's a writeup in the Archive section...just saw it last night.
Steve
Old 01-15-2007, 01:53 PM
personally,everytime i had a bad leak back there,and was convinced it was a rear main seal,it turned out being somewhere else. look carefully,there is a lot of air turbulence down there,and it can push oil all over the place,making it hard to pinpoint it's source.
Old 01-15-2007, 02:00 PM
anyone have the writeup on how to change it? or should i just drop in the SBC a little earlier than planned?l
The Tech Library on the IFSJA main page is your friend.
http://www.ifsja.org/tech/motors/rearmainseal.html
Old 01-18-2007, 01:51 AM
excellent. i'm glad to hear i don't have to drop the trans. hopefully i can get it done saturday so i can drive it to our next wheeling trip sunday. thanks guys!
Al
Old 01-18-2007, 03:59 AM
Al, I don't remember if the article mentions it but you'll want to jack the front end up and support the frame on stands on both sides so the front axle hangs down. That'll give you enough room to wiggle the oil pan in/out.
Old 01-18-2007, 04:20 AM
thanks for the tip joe!
Al
