Ok, this summer I guess I'm getting some serious interior stuff done. I pulled the original style headliner out, and it's not going back in. I'm putting a newer style Wag, custom one in its place. I see that even the '71 has the mounts for front and rear shoulder belts, which I definitely want to put in at some point. Especially the front, but the rears eventually too.
I just have a few questions about this interior stuff.
Number one: the rear shoulder belts. I can get both the top point and the very bottom installed no problem, but I am unsure on the third one (for the retractor). I know I could just drill a hole in the wheel well and use some angle iron to mount it, which is what we did on the '88, but I don't really want to if I can help it. Has anybody built/welded a bracket inside the wheel well, and drilled a hole in that interior panel? The interior panel is a homemade one so I'm not worried about modifying it...I'm just trying to figure out how to make it good and strong, but also clean. The holes are already there in the headliner, so I should be able to install the headliner and get around to the shoulder belts whenever I have time/ideas.
Number two: the cargo area. Right now it has a poorly cut, 1/2" thick rubber mat in the back, which is WAY overkill, except where it doesn't cover the floor at all. And the wheel wells and everything are still bare. I'd like to cover it all of the way from where the stainless trim goes at the back, all of the way up to where the carpet ends, just before the edge of the rise under the back seat. I want to cover the wheel wells, too...I think I'll leave the tailgate though. What do you guys recommend? I want it to be practical and relatively cheap, and also not smell up the whole Jeep (I know, I'm super picky). I don't want it to be excessively think or heavy (I have the insulation pad thing from the '88 in the back, which should provide some padding where it's critical between the cargo and the floors). Recycled is good, too, but not a requirement. I don't want to use carpet, and vinyl tends to be a little pricey. If I go with carpet, it will be very thin carpet (think a mat for your shoes, just inside the door). Just looking for something good and durable, nothing too fancy.
Thanks guys!
Thanks guys!
