Old 02-10-2021, 10:37 PM
JAG123 JAG123 is offline
Questions on 5.3LS Swap in 88 Wagon
I found a 2003 suburban with 5.3 and 4l60e
I asked the guys to pull the complete engine harness, manifolds, radiator, radiator shroud, fuel pump, fuel tank from it.
Can I even use all that stuff? I wasn’t sure so I tried to get everything I could.
Also I want to use a 4l80e - can I use the harness and trans from another GM and plug it up to the 5.3 or do I have to have an after marker harness?
Old 02-11-2021, 04:14 PM
The existing 5.3/4l60e harness needs reworking to use stand alone and modifications for a 4l80e vs. 4l60e
Depending on year of "4l80e" harness you want to swap/use it may work or require reworking.
clear as mud?
LS Vortex 5.3 Swap time - QUESTIONS littlehandegan General FSJ Tech 8 05-05-2014 09:24 PM
Engine Swap - electrical questions RallyRoach General FSJ Tech 1 11-17-2013 01:44 PM
6.0L Swap - Braking and other questions hjbald General FSJ Tech 6 04-20-2013 07:02 PM
230 tornado to V8 Engine swap questions PNW79J10 General FSJ Tech 17 12-23-2012 07:00 PM
J10 to Waggy swap questions dlmos General FSJ Tech 2 08-29-2011 06:21 AM
