Old 01-09-2021, 02:48 PM
brentwood brentwood is offline
401 smoking issue
Hey guys, my 401 is smoking badly. It smokes a bit at idle and gets worse at higher rpm.
It's not burning oil or coolant. It starts right up, idles well at 950 rpm, runs strong and sounds good.
I readjusted air fuel mixture, made sure choke is opened all the way and double checked timing.
Everything seems fine besides excessive smoke, which is primarily coming from right side of exhaust.
What do you guys suspect the problem is?
1982 Wagoneer w/258, Rusty's 4in spring lift, motorcraft 2100, 32x11.5x15 bfg's *sold*
1972 J4000 Chevy 350, th350, divorced Dana 20, Holley carb, alcan 4in springs, 35in BFGs on 15in slots
1978 J10 golden eagle w/Levis interior, 401and th400, Edelbrock avs2, 32x11.5 falken rubitreks on stock golden eagle wheels
Old 01-09-2021, 04:14 PM
levelhead's Avatar
levelhead levelhead is offline
A faulty modulator valve on your transmission can cause your 401 to suck trans fluid through the vacuum line to it into the intake manifold and burn it. Pinch off or plug the vacuum line temporally (your trans won't shift ) and see it that stops it. If so replace your modulator valve.
1988 GW (2)
1980 Cherokee Laredo
1979 Wagoneer
1976 J10 401
1977 Wagoneer 401
1977 J10 4 speed
1969 J3000 (2)
1955 CJ3B
Old 01-09-2021, 04:58 PM
SC/397's Avatar
SC/397 SC/397 is offline
This might sound strange but check for a valve cover gasket leak first. If a valve cover is leaking and a exhaust manifold is leaking, the exhaust manifold or header will draw oil in to it and of out the tail pipe in smoke.
The Squeaky Wheel gets replaced in my world
Old 01-09-2021, 06:51 PM
Cliff's Avatar
Cliff Cliff is offline
I had a strange problem where my fuel tank vent line (the one that goes to the charcoal canister) had rusted closed, and on warm days the fuel was building pressure in the tank and pressurizing the fuel line to the carb and richening the mixture, and making tons of black smoke under acceleration. Since this is affecting one side more than the other I wouldn't suspect this, but thought I would throw it out there anyway.
Cliff Danley
1977 Cherokee S
Old 01-10-2021, 12:41 AM
Thanks, I'll check that next time I work on the truck.
Old 01-10-2021, 12:51 AM
Not seeing a valve cover leak. Installed new gaskets a few months ago.
This reminds me that I plugged exhaust manifold emissions ports back in the summer. The driver side went smoothly. On the passenger side, pieces of inner tube came out with stock bolts. Could this be my issue?
Old 01-10-2021, 12:52 AM
Thanks for your reply. I have a fuel pressure regulator set to 5psi.
Old 01-15-2021, 07:41 PM
jammer1 jammer1 is offline
Could it be bad valve seals (letting oil into the cylinder). May be able to see it on the plugs.
Old 01-16-2021, 10:05 AM
Originally Posted by brentwood
...It's not burning oil or coolant...Everything seems fine besides excessive smoke, which is primarily coming from right side of exhaust.
I don't see where you've described what the smoke smells like.
You said it's not burning oil or coolant, but how did you verify that?
You also stated it's coming from the "right side of exhaust". Do you mean it's emanating from inside the engine bay or the right side exhaust pipe (assuming you have dual exhaust)?
Hard to help troubleshoot when we're not right there with you, but first I'd ensure you've properly identified the type of smoke (maybe you have, it's just not clear in your posts thus far), then work on identifying where exactly the issue is coming from.
--Rob--
My build thread:
My Howell TBI Install How-To:
Old 01-17-2021, 11:59 PM
I'll check, thanks
Old 01-18-2021, 12:14 AM
My oil and coolant levels aren't noticeably dropping. Smoke doesn't smell like coolant.
Yes straight dual exhaust, no x or H pipe.
Drivers side has "normal" amount of exhaust smoke.
Passenger side has excessive smoke that gets worse as engine warms up and at higher rpms.
Smoke comes from passenger side tailpipe and back of engine bay/front of cab area on passenger.
It's not safe to drive, the fumes are getting into the cab.
I have to spend some time looking at it and I'll update the post if I find anything.
Old 01-18-2021, 01:58 AM
That helps narrow it down. If not smelling of coolant, it also won't be carb related since the effect would be seen out both pipes, so it has to be something related to that passenger side.
Does it smell like unburned gas or oil? You didn't mention that either.
I'll assume oil since you didn't mentioned it misfiring from a bad plug or lack or spark on that side, so maybe the valve seals as jammer said, gummed up rings not sealing a cylinder properly, or something else along those lines.
I had gummed up rings on my high mileage Saturn 4-banger. I poured Seafoam into the crank to loosen all the sludge and deposits, ran that for quite a few miles, and that eliminated the problem for me. Hopefully your plugs give you more info.
--Rob--
My build thread:
Old 01-18-2021, 08:28 AM
Are you getting a lot of blow by out of the vents?, If your getting more smoke when warmed up I would look at valve guide seals, the umbrella type get hard and break off with age, viton seals are better but require machining of the head.
Old 01-24-2021, 02:40 PM
I tried seafoam in fuel and crankcase oil last week. Also used a bottle of the seafoam for carb/intake.
I ran it for a couple hours since. Can't drive it because it smokes too much.
The smoke is a light grey whitish color.
I pulled passenger side spark plugs... No oil on plugs but they did have a lot of soot/carbon on them.
I tried pinching off trans modulator line...made no difference.
Still no noticeable oil or coolant loss.
I really don't know what to do and can't afford an engine rebuild right now. I may just end up selling it.
Old 01-24-2021, 04:15 PM
Heep-J4000's Avatar
Maybe not a question that makes sense , but how is the brake fluid level in reservoir?
Maybe doing a compression test also to rule out all possibilities!?
Trucks/car's from the past:
Old 01-24-2021, 04:22 PM
levelhead's Avatar
If the smoke is white you are probably burning coolant. I assume being from NJ you are running a 50/50 mix of water and antifreeze. Go to your tailpipe and have a whiff of the smoke. If it smells sweet that is antifreeze. Your just not burning enough to notice the drop in your level.
1988 GW (2)
1979 Wagoneer
1976 J10 401
1977 Wagoneer 401
1977 J10 4 speed
1969 J3000 (2)
1955 CJ3B
Old 01-24-2021, 08:32 PM
From brentwood's post above:
I don't remember seeing that last post, but what do you mean by "pieces of inner tube coming out with stock bolts"?
Again, we're not there with you, but this makes no sense to me, so I'm now wondering if you have rubber or plastic crap burning off in that passenger side exhaust pipe and have an exhaust leak somewhere, seeing as how you said earlier you also have smoke coming from the engine bay near the firewall.
Still scratching my head, but it certainly sounds like the Seafoam is burning off now, what with the white smoke, but without being there it's difficult to help troubleshoot. If it's worse and it's been hours later, it certainly sounds like valve seals or rings are allowing some of the crank case Seafoam into the combustion chamber. Video and pics of smoke and plugs would help. Only you can know the difference between coolant, gas, or oil burning off, but it certainly sounds like valve seals or rings are the culprit.
As mentioned, get a compression and leak-down test done. It may not be all that expensive to fix.
--Rob--
My build thread:
Old 01-25-2021, 11:53 AM
My bet is Valve seal(s).
If it is only one side and it's not coolant or trans fluid getting in, that leaves:
Head gasket
Valve seals
Valve guides
rings
Cracked head or cylinder
I guess maybe the intake manifold to head gasket/pan maybe if it is pulling oil up but I am not sure that is really possible
You really need to do a compression/leak down test to determine for sure. If it is your valve seals, I have a set of Fel Pro ones left over from my rebuild and you can have them for shipping. With the right tools you can replace all 16 of them on a Saturday.
Old 01-30-2021, 05:48 PM
Head gasket
Valve seals
Valve guides
rings
I'll take the valve seals. Message me with info when you get a chance. Thanks
Old 01-30-2021, 05:50 PM
Thanks for the replies guys. I'll update when I get time to work on it again.
Stock Cam timing numbers... 360 and 401 Tinkerjeep General FSJ Tech 26 04-11-2013 01:56 PM
401 to 360 Swap What do I need to do? flyusmc General FSJ Tech 6 11-12-2007 08:50 AM
The 401 revisited Elliott General FSJ Tech 20 12-14-2003 12:41 PM
401 info request fdwyer General FSJ Tech 8 04-26-2001 06:18 PM
