Old 01-06-2021, 06:57 PM
Triumph215 Triumph215 is offline
Oil pump housing gasket replacement
How easy is it to pop the oil pump housing off to replace the gasket? I have a leak there that needs addressed. I have a 215 Olds with a similar oil pump setup, super easy to get everything on and off. Would like to check the pressure relief valve and the end play while the cover is off.
1977 Wagoneer
1964 Triumph TR4
2009 BMW R1200 GS
Old 01-06-2021, 07:40 PM
Cliff's Avatar
Cliff Cliff is offline
Piece of cake. If you have a TSM take a look at the exploded view. If you don't have a TSM look at the oil pump diagram for the rebuild kit at BJ's Off Road. (www.bjsoffroad.com).
Cliff Danley
1977 Cherokee S
Old 01-06-2021, 07:41 PM
Cliff's Avatar
https://www.bjsoffroad.com/Melling-A...Kit_p_630.html
Cliff Danley
1977 Cherokee S
Old 01-06-2021, 11:01 PM
Rats, my BJs order just shipped. I did not realize they had this part, will for sure order it shortly. I do have the TSM.
Thanks !
1977 Wagoneer
1964 Triumph TR4
2009 BMW R1200 GS
Old 01-07-2021, 10:29 AM
Heep-J4000's Avatar
For the AMC 360 engine it's not to difficult ,but make sure you don't drop the gears on the ground when removing the cover.
Trucks/car's from the past:
Old 01-08-2021, 10:39 AM
Jeep Doctor
It's very easy; you can see the details in the video below at about the 3:55 mark:
https://youtu.be/gSqd_f3v21w
Old 01-10-2021, 10:23 AM
Excellent, exactly what I expected and nice to see so there are no surprises.
Much appreciated.
1977 Wagoneer
1964 Triumph TR4
2009 BMW R1200 GS
Fuel Pump replacement issues Jeremyatom General FSJ Discussion 18 06-16-2016 09:40 PM
Newbie question re: fuel pump replacement GotMeAwoodie General FSJ Tech 8 12-16-2011 04:40 PM
Leaking Water Pump Gasket Walt General FSJ Tech 4 04-04-2010 11:19 AM
wrong oil pump gasket??? sea2seajt General FSJ Tech 5 02-16-2009 06:45 AM
badaboom - oil pump cover gasket. J10Mike General FSJ Tech 3 09-11-2003 02:42 AM
