Old 04-19-2021, 10:25 PM
Full Size Jeeper's Avatar
BJ's OFF-ROAD headliner install
You have to give some measurements before you order. My guess is that jeep made a few changes in where they split the headliner. It is made to order and took a few weeks to come in, maybe three. It comes with some basic instructions. I was at a disadvantage due to the fact, my original headliner was in bad shape and was removed years ago and did not remember much about how I pulled it out. It would have been better to pull the old one out and replace it with the new one within a few weeks. I would not leave it in the box for a long period of time. I pulled mine out the day it arrived.
Old 04-19-2021, 10:29 PM
This is what you can expect when you pull it out of the box. I was a little worried if it would ever lay flat, but it was fine.
Old 04-19-2021, 10:30 PM
Old 04-19-2021, 10:32 PM
This is the back side, looks to be well made.
Old 04-19-2021, 10:35 PM
New dome lights wired in and installed.
Old 04-19-2021, 10:44 PM
I installed the rear piece first, but I had to remove it because the front piece has some predrilled holes for the sun visors at the front and center, and it really can only go in one place. I would do the front piece first. Here is the back piece before I pulled it out.
Old 04-19-2021, 10:45 PM
Old 04-19-2021, 10:48 PM
My factory trim is cracked, so I'am going to make my own from a piece of aluminum trim I found a Home Depot.
Old 04-19-2021, 10:51 PM
This is what I used, and it looks and fit pretty good. But I wish someone made new trim.
Old 04-19-2021, 11:17 PM
Repainted the front and rear trim flat black.
Old 04-19-2021, 11:30 PM
Painted the new trim.
Old 04-19-2021, 11:33 PM
I used Velcro to hold the trim in place, time will tell if this was a good idea.
Old 04-19-2021, 11:34 PM
These are the side pieces I cut.
Old 04-19-2021, 11:39 PM
Will have to touch up the paint a little, but I think it looks pretty good.
Old 04-19-2021, 11:40 PM
Old 04-19-2021, 11:43 PM
Old 04-19-2021, 11:50 PM
So, I did this install with no help, which I do not suggest. Two people would make it a lot easier. Very good fit and well made. Glad I went with it. Hope this helps someone trying to decide if this is a project they might want to take on.
Old 04-19-2021, 11:56 PM
The kit came with this extra material. I think it is to recover the sun visors, but not 100 percent sure.
Old 04-20-2021, 03:56 AM
Brynjminjones's Avatar
I don't know if it's just me, but I can only see the last few photos. It looks great though!
I need to do the same in mine, but need to figure out how to get one shipped to the UK first.
1991 Grand Wagoneer - Hunter Green. All stock. Rebuilt 360 with Melling MTA-1 cam.
1998 Cherokee (XJ) 4.0
1997 Grand Cherokee (ZJ) 4.0
1974 Ford F100 390
Old 04-20-2021, 04:18 AM
wiley-moeracing wiley-moeracing is online now
not just you.
D20 Jbfab twin stick install Dbshea General FSJ Discussion 4 03-09-2015 07:49 PM
headliner install Rainman General FSJ Tech 16 02-24-2010 06:49 PM
Headliner Replacement (Lotsa Pics) chuckchili General FSJ Tech 13 03-19-2009 06:58 PM
AGR Steering install and thoughts will e General FSJ Tech 3 04-08-2008 08:46 AM
custom headliner ? Mavawreck General FSJ Tech 5 03-22-2003 01:50 PM
